194
#100641 - 03/09/06 12:13 AM
winch setups
If you have a winch what is your set-up?? Meaning what kind of winch, battery, alternator, or anyother kind of mod you may of had to do besides a bumper to get your winch the power it needs..
#100643 - 04/09/06 07:15 AM
Re: winch setups
Warn 9.5 XP...just bolted it to the bumper, ran the wires to the battery and ground, and it worked. I had already upgraded to a Optima yellow....and I later added a remote solinoid plug to the top of the bumper to avoid reaching to hook up the control. I'm still running on the crappy 80 amp OEM alternator that refuses to die. I also swapped out the wire rope and roller fairlead to run synthetic winch rope and an aluminum fairlead, saved 45 lb.
#100645 - 04/09/06 04:57 PM
Re: winch setups
Originally posted by TJ:
 nice cross member there TJ.. you have any pics fo the fairheads..
#100646 - 04/09/06 09:00 PM
Re: winch setups
I got a Warn XD9000i mounted in my Shrock bumper (feet first). I am running AmSteel Blue Synthetic line, a self closing hook and an aluminum hawse fairlead. I am currently running the stock battery, but will be looking at an Excide Orbital soon.
#100647 - 05/09/06 02:44 AM
Re: winch setups
Warn M8000 in an ARB bumper with a Hawse fairlead. Alternator is stock and battery is a 750 CCA Optima yellow top.
#100648 - 05/09/06 08:49 PM
Re: winch setups
Originally posted by Paul H: I have a MileMarker winch and an optima yellow top with Calmini bumper. Nothing else and works great.
 I have the same bumper, and battery. I have the Harbor Freight / Chicago Electric 9k winch.. a direct rip off for the milemaker.. Mine looked like that 2 years ago.. The Zip Tie of the left is CRITICAL.. without it the electronics wiggle enough to fail the mounting plate at the 2 bolts to the winch body.
#100649 - 07/09/06 02:45 PM
Re: winch setups
I have a 9k T-max on a shrock bumper with optima yellow top.
#100650 - 07/09/06 06:14 PM
Re: winch setups
Originally posted by MediStorm: I have a 9k T-max on a shrock bumper with optima yellow top. How much have you used your T-Max? I am looking to go T-Max on my 05, as big as I can stuff in the Shrock Bumper. Also want that bad A$$ remote.
#100651 - 07/09/06 06:16 PM
Re: winch setups
Loc: LA (Lower Alabama)
Optima yellow-top, Shrockworks winch bumper and... ...a Hi-Lift jack and the Hi-Lift off-road kit. So I'm cheap - sue me.
2002 Just Blue XE 4x4
#100652 - 08/09/06 08:49 AM
Re: winch setups
Loc: Fort Carson, CO
XD9000i, Optima yellow top, and mean green alternator on a Calmini bumper. I can run my 400W of lights, high beams, and winch all at the same time. Axle
#100653 - 09/09/06 08:32 AM
Re: winch setups
I was thinking about getting one of THESE for the time being (at least until I get my new bumper): I'm cheap too, & $40 seems like a good deal.
#100654 - 09/09/06 08:49 AM
Re: winch setups
Loc: Eddy, TX..
MM8000 on an ARB bumper with an Optima Red Top. MacGuyverized the bumper so cluth is accesible from on top as is the controller box. I use a wireless remote whenever possible... I like the security/safety it provides even if only in mindset Edited to ask: Noted in the pics most of you seem to take added time and effort to spool your cables very neatly. Is there a functionality reason? I just wind mine as fast and easily (lazily) as I can after use.
"Caribbean Soul land locked in Texas"
#100655 - 10/09/06 03:18 PM
Re: winch setups
Loc: San Jose, CA
That cable appears to be spooled neatly because it hasn't been used yet!
Actually, it is important to spool it carefully to prevent the cable from getting stuck inside itself on hard pulls, making it a real pain to unspool the cable without a load. Usually the last wrap of the cable around the drum doesn't need to be neatly/tightly spooled because you typically unwind it for winching anway, but the lower wraps should be tight. In severe cases of loosely wrapped cable, the wire can actually get crimped or damaged.
#100656 - 10/09/06 03:18 PM
Re: winch setups
Originally posted by pluvo: I was thinking about getting one of THESE for the time being (at least until I get my new bumper):
I'm cheap too, & $40 seems like a good deal.That would not even help at all, 0%. Dont bother.
#100657 - 10/09/06 06:13 PM
Re: winch setups
Loc: High Point, NC
I'm cheap too, & $40 seems like a good deal.This might be equivelent to an ATV winch. I can push our 5500 pound boat when it's on the trailer, so I can't figure 6000 rolling weight would be much help besides pulling a boat onto a trailer from the water.
'00 4x4 V6 XE
#100659 - 10/09/06 08:41 PM
Re: winch setups
Originally posted by Lightning: Originally posted by pluvo: [b]I was thinking about getting one of THESE for the time being (at least until I get my new bumper): I'm cheap too, & $40 seems like a good deal. This might be equivelent to an ATV winch. I can push our 5500 pound boat when it's on the trailer, so I can't figure 6000 rolling weight would be much help besides pulling a boat onto a trailer from the water.[/b]A friend of mine had one, you would think you couls back the trailer 1/2 into the water, and winch the boat up onto it.. no such luck.. Insanely weak, and slow as crap under load.. We did a test in his court.. I gould push his f250 faster then the winch could pull it, on level ground.. Neither me or the winch could drag the truck up his driveway.. If is can't pull a 5k lb truck on a paved incline, I would hate to rely on it to unstuck a truck..
#100660 - 25/10/06 03:37 PM
Re: winch setups
Just scored a great deal on a Warn M8000 to go in the front Shrock. Woo hoo!
Quick question, tho (haven't picked it up yet so haven't read any install instructions).
Any tips for an easy install? Do I need to get any "mounting kit" or does that sucker just bolt on there?
#100661 - 26/10/06 08:04 AM
Re: winch setups
They just pretty much bolt up. The M8000 is a remote solenoid right? If so, shrock sends a mounting bracket for it.
#100663 - 26/10/06 12:48 PM
Re: winch setups
Thanks guys. I pick up the winch tomorrow and the bumper should come in 1-2 weeks; I'm pretty stoked.
One more question, do they give you enough cable to move that solenoid away from the winch a bit? Fabbing up a mount or a plate is no problem, and I'm thinking it would be nice to get it out of the way as much as possible.
#100664 - 26/10/06 02:11 PM
Re: winch setups
My 05 bumper came with a mount that would mount the solenoid on top of the bumper in the center. I have an integrated solenoid so I didn't need it so I have no pics.
#100665 - 26/10/06 02:18 PM
Re: winch setups
Originally posted by Bobby B.: Thanks guys. I pick up the winch tomorrow and the bumper should come in 1-2 weeks; I'm pretty stoked.
One more question, do they give you enough cable to move that solenoid away from the winch a bit? Fabbing up a mount or a plate is no problem, and I'm thinking it would be nice to get it out of the way as much as possible. I can't speak for all winches but I know mine came with enough to move it away if need be.I mounted mine there cause I'm using the hole that Shroclworks provides on his bumper to plug in my controller.
