132
#104189 - 08/07/03 11:21 PM
Hand Throttle
Loc: Central New Jersey, United Sta...
Hey,
Is anyone running one besides Mobycat? I have a mtb lever and just need a tandem rear brake cable to get started.
Best regards,
Michael AKA Miikkaa
Earth people suck.
#104191 - 09/07/03 05:56 AM
Re: Hand Throttle
Loc: ATX
This is the model from Rubicon Express : RE Throttle I don't know if I necessarily like this one that much... I think the throttle shown on the MAXC site is much better... just my own opinion... ![[Wave]](graemlins/wave.gif)
XOCEverything you need, if you don't mind the b.s.West Ham UFC -- Come On You Irons!!! www.myspace.com/kraigslist Kraig
#104192 - 09/07/03 04:38 PM
Re: Hand Throttle
Best regards,
Michael AKA Miikkaa
Earth people suck.
#104196 - 09/07/03 07:31 PM
Re: Hand Throttle
Originally posted by Mobycat: Originally posted by xoc: [b]Just don't eject a CD into it in 1st, 3rd or 5th No doubt! Shift the brake handle to either side just a tad.[/b]I'm fine in 5th  The lever will only be on when I off-road, where the only thing on is the CB and/or FRS. Gotta' love quick-release levers. Too bad the the cool 5spd. knob I found in my Z parts has different threads  I'm also dying to find a lever from that mtb. groupo Campagnolo put out a while ago. BTW Mobycat, I'm curious as to why you no longer use yours? I heard you removed it soon after the install.
Best regards,
Michael AKA Miikkaa
Earth people suck.
#104197 - 09/07/03 09:02 PM
Re: Hand Throttle
Originally posted by Miikkaa: Originally posted by Mobycat: [b] Originally posted by xoc: [b]Just don't eject a CD into it in 1st, 3rd or 5th No doubt! Shift the brake handle to either side just a tad.[/b] I'm fine in 5th The lever will only be on when I off-road, where the only thing on is the CB and/or FRS. Gotta' love quick-release levers. Too bad the the cool 5spd. knob I found in my Z parts has different threads I'm also dying to find a lever from that mtb. groupo Campagnolo put out a while ago. BTW Mobycat, I'm curious as to why you no longer use yours? I heard you removed it soon after the install.[/b]Yeah, I did. (Was probably about 9 months after the install.) I've thought about putting it back. It worked great, until... Was playing around with it (not offroad, just in a parking lot) and it went "snap". The cable broke right at the throttle wheel. Should've gotten better cable - the one I had was el cheapo.
#104198 - 09/07/03 10:01 PM
Re: Hand Throttle
Originally posted by Mobycat: Originally posted by Miikkaa: [b] Originally posted by Mobycat: [b] quote: Originally posted by xoc: Just don't eject a CD into it in 1st, 3rd or 5th No doubt! Shift the brake handle to either side just a tad.[/b] I'm fine in 5th The lever will only be on when I off-road, where the only thing on is the CB and/or FRS. Gotta' love quick-release levers. Too bad the the cool 5spd. knob I found in my Z parts has different threads I'm also dying to find a lever from that mtb. groupo Campagnolo put out a while ago. BTW Mobycat, I'm curious as to why you no longer use yours? I heard you removed it soon after the install.[/b]Yeah, I did. (Was probably about 9 months after the install.) I've thought about putting it back. It worked great, until... Was playing around with it (not offroad, just in a parking lot) and it went "snap". The cable broke right at the throttle wheel. Should've gotten better cable - the one I had was el cheapo. Ahh, I understand now. I wanted to decrease the action so I used two fender washers I had laying around with a thin nylon gear spacer of slightly less diameter to run the cable over and to provide a way to anchor it (one big sandwich). I'm going to eventually rig some sort of cable anchor on it and run a spacer wider than the cable for a set-up like the stock cam rollers have. This should allow the cable to ride over it and eliminate the stress. BTW thank you for the excellent write-up in the MAXC mod section!! I think I had that linked before I even got the X
Edit: I suck at spelling
Best regards,
Michael AKA Miikkaa
Earth people suck.
