0 registered (), 131 Guests and 0 Spiders online.
#11536 - 29/05/08 10:47 AM Help me! How do I tow my Xterra?
How do I tow my xterra? We need to tow it about 4 hours. We will be towing it on our 1990 Ford Bronco. Can I flat tow it? or rear end up or front end up? or just trailer it?
#11537 - 29/05/08 10:54 AM Re: Help me! How do I tow my Xterra?
Trailering it is always better. It saves putting the miles on the bearings, etc. All 4 wheels off the ground.
#11538 - 29/05/08 11:14 AM Re: Help me! How do I tow my Xterra?
The real risk is the transfer case. You'll blow it up if you don't tow the vehicle properly. There are two schools of thought:
1) Put the T-case in neutral, and put the transmission in neutral. You're good to go, in theory. This won't work with an auto, though. And some guys will swear that this method will tear your t-case apart anyways.
2) Trailer it. This method has never blown up a t-case. Ever. Not even once.
There you go - Have a safe trip!
Scott
#11539 - 29/05/08 12:38 PM Re: Help me! How do I tow my Xterra?
Lightning Offline
Loc: High Point, NC
There's a whole section on towing it in the owners manual. Never had to tow one myself.
'00 4x4 V6 XE
#11540 - 30/05/08 05:00 PM Re: Help me! How do I tow my Xterra?
At best case, you want to trailer it so that none of the 4 wheels are on the ground.
At worst case (if your X is 2WD) you want to tow it with the rear-end raised up on a dolly of some sorts so that only the front tires are making contact.
If you've got a 4WD X and you have a worse case scenario it'd involve removing the driveshaft leading to the rear axle and tow it with the front of the vehicle raised up on a dolly.
#11541 - 30/05/08 05:05 PM Re: Help me! How do I tow my Xterra?
Ah ha! So there is no transfer case neutral position. I knew it wasnt there!
#11542 - 30/05/08 06:09 PM Re: Help me! How do I tow my Xterra?
Yes, there is a neutral position in the t-case. If you look real close, you'll see a neutral selection.
I don't know what you're saying here...
Christi's X is 4x4 - read the profile. My original post reflects many of the thoughts on how to tow a 4x4 vehicle.
Scott
#11543 - 30/05/08 08:17 PM Re: Help me! How do I tow my Xterra?
Kaiser Offline
FYI, it's just 4 bolts to undo the rear of the driveshaft where it connects to the diff... not that big a deal to undo it and ziptie it up to something.
#11544 - 30/05/08 08:22 PM Re: Help me! How do I tow my Xterra?
"Yes, there is a neutral position in the t-case. If you look real close, you'll see a neutral selection."
2nd Gen Xterras there aint!
Post me a picture of the transfer case neutral position because I cant find it!!---And yes--I've read the owners manual.
#11545 - 30/05/08 09:27 PM Re: Help me! How do I tow my Xterra?
well on the pre new gen X, it says it right on the shifter knob. these new fangled xterra's with their electronic 4x4 switch probably wont have one, but how would i know. i own a 2003.
#11546 - 31/05/08 06:11 AM Re: Help me! How do I tow my Xterra?
This whole Gen I vs. Gen II thing... My mistake on presuming we were in Gen I mode.
