221
#166137 - 30/12/06 12:39 PM
Originally posted by XPLORx4: Originally posted by Mobycat: [b]What if it can't do anything *beyond* matching it? Then, again, the plane needs bigger engines.[/b]You're avoiding the question. Would the plane be able to keep from moving backwards due to the friction? And, because of that, stay in one place (since it's only matching, not overcoming)?
#166138 - 30/12/06 12:42 PM
Loc: San Jose, CA
Originally posted by Mobycat: Would the plane be able to keep from moving backwards due to the friction? And, because of that, stay in one place (since it's only matching, not overcoming)? If the plane's engines were throttled up only enough to equalize the friction produced by the wheel bearings, then, yes, you could have a plane sitting motionless on a moving conveyor belt.
#166139 - 30/12/06 12:45 PM
Originally posted by XPLORx4: Originally posted by Mobycat: [b]Would the plane be able to keep from moving backwards due to the friction? And, because of that, stay in one place (since it's only matching, not overcoming)? If the plane's engines were throttled up only enough to equalize the friction produced by the wheel bearings, then, yes, you could have a plane sitting motionless on a moving conveyor belt.[/b]Bingo. It's the same thing. It doesn't matter which one started the event - either way, there is an equal and opposite reaction.
#166140 - 30/12/06 12:45 PM
Loc: San Jose, CA
Originally posted by XPLORx4: If the plane's engines were throttled up only enough to equalize the friction produced by the wheel bearings, then, yes, you could have a plane sitting motionless on a moving conveyor belt. HOWEVER, since the original scenario specifies that the plane must have some kind of speed so that the conveyor can reverse-match it, how do you want to measure speed? In order for the conveyor to even get going, the plane would have to have some kind of ACTUAL speed...
#166141 - 30/12/06 12:45 PM
Originally posted by NY Madman: ....The plane is moving. However... once the conveyor and the plane's speed are matched exactly... to an outside observer the plane would "appear" to be stationary. Remember... "appear" stationary.
Are we at least on the same page regarding that fact? Heck no! The plane moves absolutely! It's thrusters push against the atmosphere. Please read above! F = ma a = F/m
#166142 - 30/12/06 12:46 PM
Originally posted by XPLORx4: Originally posted by XPLORx4: [b]If the plane's engines were throttled up only enough to equalize the friction produced by the wheel bearings, then, yes, you could have a plane sitting motionless on a moving conveyor belt. HOWEVER, since the original scenario specifies that the plane must have some kind of speed so that the conveyor can reverse-match it, how do you want to measure speed? In order for the conveyor to even get going, the plane would have to have some kind of ACTUAL speed...[/b]That's the whole crux of it, though. What's the speed relative to?
#166145 - 30/12/06 12:48 PM
There is ZERO power being put directly to the wheels. They just spin. In fact, the plane can take off while the wheels are actually spinning backwards due to the fact that the wheels have no effect on propultion.
Ever wondered why no one has ever seen a jet on a dyno?
I also used the Harrier reference because there are two forces at work there. First it uses downword thrust to achieve lift, and then forward propultion to achieve speed.
Try to imagine a hovering Harrier. It is hovering in mid air and then when maximum thrust is applied to forward motion it reaches speed and is no longer reliant on downword thrust to defy gravity. But by "floating" it is eliminating the need for a runway, thus no need for wheels. Yet, from a standing start, mid air, it is able to achieve flight.
#166147 - 30/12/06 12:50 PM
Try to imagine a hovering Harrier. It is hovering in mid air and then when maximum thrust is applied to forward motion it reaches speed and is no longer reliant on downword thrust to defy gravity. But by "floating" it is eliminating the need for a runway, thus no need for wheels. Yet, from a standing start, mid air, it is able to achieve flight. It is NOT able to achieve flight from a mid air standing start. The vents gradually turn as the plane begins moving forward. Try taking that harrier and switching the vents instantaneously from vertical to horizontal. It's going to drop like a rock. Because there is no lift on the wings.
#166148 - 30/12/06 12:50 PM
Loc: San Jose, CA
Originally posted by Mobycat: It doesn't matter which one started the event - either way, there is an equal and opposite reaction. There, you are making the assumption that the harder the engines pull, the force of friction on the wheel bearings equalizes the engine thrust. Your response assumes that the wheel bearings would have an infinite amount of friction that is opposed by an infinite amount of engine thrust. In real life, of course, we know that at some rotational speed, the tires would fly apart or the wheel bearing grease would overheat and cause the landing gear to self destruct.
#166149 - 30/12/06 12:52 PM
Originally posted by socalpunx: There is ZERO power being put directly to the wheels. They just spin. In fact, the plane can take off while the wheels are actually spinning backwards due to the fact that the wheels have no effect on propultion.
DING DING DING DING DING!!!! It's IMPOSSIBLE to put a plane on a dyno without strapping it down so it doesn't move forward! The conveyor belt scenario is basically a theoretical dyno tester!
#166150 - 30/12/06 12:52 PM
Loc: Florida
Originally posted by JeffW:
Heck no!
Please read above! The plane is moving. You haven't answered the question. I'll put it another way.... If an outside observer were to look at the hypothetical experiment being discussed while it is in progress... keep in mind that the conveyor and the plane's speed are matched... Tell me what that outside observer would see? Describe the scene from their eyes.
#166151 - 30/12/06 12:55 PM
Loc: San Jose, CA
Originally posted by NY Madman: Tell me what that outside observer would see? Describe the scene from their eyes. They would see a plane get onto a runway, jerk forward for a microsecond, then move very slowly forward until the tires and wheel bearings got too hot and self-destructed. Then they'd see some emergency vehicles and eventually an evacuation of the aircraft.
#166152 - 30/12/06 01:00 PM
Originally posted by Mobycat: Originally posted by socalpunx: [b] I also used the Harrier reference because there are two forces at work there. First it uses downword thrust to achieve lift, and then forward propultion to achieve speed.
Try to imagine a hovering Harrier. It is hovering in mid air and then when maximum thrust is applied to forward motion it reaches speed and is no longer reliant on downword thrust to defy gravity. But by "floating" it is eliminating the need for a runway, thus no need for wheels. Yet, from a standing start, mid air, it is able to achieve flight. Try taking that harrier and switching the vents instantaneously from vertical to horizontal.
It's going to drop like a rock. Because there is no lift on the wings.[/b]At what moment is vertical thrust insignificant and horizontal thrust applied? Aren't we still talking about achieving maximum thrust in flight without the use of the wheels making the wheels irrelevant. I still think it would take off in the conveyor scenario, but why is it that jet pilots appply thrust gradually as opposed to appplying full throttle and reducing runway distances? Isn't the thrust alone enough to push the plane into flight? Does the plane on the conveyor belt also create it's own atmospheric conditions like a tornado? Althought it appears that it is not moving it of course we know that it is. Due to speed and friction of the wheel is there enough motion to create wind and simulated atmosphereic conditions of movement?
#166155 - 30/12/06 01:04 PM
I have a truck Do you give a fuck? Maybe it needs cleaning Maybe this has another meaning Do you know what it is yet?
#166156 - 30/12/06 01:04 PM
Loc: Georgia
Originally posted by socalpunx: Originally posted by Mobycat: [b] Originally posted by socalpunx: [b] I also used the Harrier reference because there are two forces at work there. First it uses downword thrust to achieve lift, and then forward propultion to achieve speed.
Try to imagine a hovering Harrier. It is hovering in mid air and then when maximum thrust is applied to forward motion it reaches speed and is no longer reliant on downword thrust to defy gravity. But by "floating" it is eliminating the need for a runway, thus no need for wheels. Yet, from a standing start, mid air, it is able to achieve flight. Try taking that harrier and switching the vents instantaneously from vertical to horizontal. It's going to drop like a rock. Because there is no lift on the wings.[/b] At what moment is vertical thrust insignificant and horizontal thrust applied? Aren't we still talking about achieving maximum thrust in flight without the use of the wheels making the wheels irrelevant.
I still think it would take off in the conveyor scenario, but why is it that jet pilots appply thrust gradually as opposed to appplying full throttle and reducing runway distances? [/b]That question I can answer: engine wear. Maximum thrust is not used by airliners for takeoff, "takeoff thrust" is computed using the final weight and balance figures and is usually not maximum thrust but a percentage thereof. This minimizes engine wear and allows a safety cushion of available power if needed.
#166157 - 30/12/06 01:07 PM
Loc: Florida
Originally posted by BlueSky:
Can the belt really "match" the plane's speed, and if so, what exactly does that mean? To me it means it negates the plane's forward motion, just like a dyno does to a car or a grocery store conveyor does to an orange. You are getting VERY CLOSE. The plane is in motion. However not in conventional terms. We need to know the exact relationship of the plane and the atmospheric air at this point in time.
#166158 - 30/12/06 01:08 PM
Loc: San Jose, CA
Originally posted by BlueSky: I think whoever said the question of what speed means in this instance is right. Can the belt really "match" the plane's speed, and if so, what exactly does that mean? To me it means it negates the plane's forward motion, just like a dyno does to a car or a grocery store conveyor does to an orange. How can a conveyor belt touching wheels that have no power source negate movement caused by engines pushing against air?
#166159 - 30/12/06 01:09 PM
So if necessary, and engine life were not a factor for this excersize, you could potentially go from zero to takeoff thrust with wreckless abandon set the wing flaps for takeoff and...
Take off. Right?
#166160 - 30/12/06 01:12 PM
Loc: San Jose, CA
Originally posted by BlueSky: That question I can answer: engine wear. Maximum thrust is not used by airliners for takeoff, "takeoff thrust" is computed using the final weight and balance figures and is usually not maximum thrust but a percentage thereof. This minimizes engine wear and allows a safety cushion of available power if needed. It's also to make it more comfortable for passengers as well as to reduce stress on the airframe. Theoretically it could be possible for a plane to be made with engines so powerful that they could rip themselves from the wings if they were turned on full blast while the plane isn't moving.
