142
#176212 - 06/04/01 09:38 AM
First Scratch
Loc: New Jersey
Yesterday I went to pick up my wife at the train station. As she started open the door I said becareful with the light pole, as I was parked on an incline. As she was getting on the truck, she let the door go, which banged the metal light post. I gave her a big speech about been more careful... There was no mark on the door.
30 minutes later, I was getting on the truck after a stop. When I closed the door, the seat belt buckle was caught by the door. The result, 2 scratches on the inside frame of the door, on top of the spec label. One of the scratches is very deep.
I was thinking of stopping at the dealer to get some touch-up paint.
Any recommendations, besides being nicer to my wife?
------------------ 2001 Xterra SE 4X4 Auto Aztec Red
#176213 - 06/04/01 10:18 AM
Re: First Scratch
Loc: Huntington, NY
The first one is always the one that hurts most...  Best bet, get some touch up paint and apply it with a match, not the brush that comes with it. If it's still within the top or color coat, get a polishing wax and try to take the scratch out a bit, then follow it with good pure wax. Then just try to forget about it... ------------------ 2001 Solar Yellow SE 4x4 V6 5spd
#176214 - 06/04/01 10:35 AM
Re: First Scratch
7
Loc: AZ
I feel your pain.  Follow BP's instruction. ------------------ There is a fine line between "addiction" and "obsession".
#176215 - 06/04/01 10:48 AM
Re: First Scratch
Loc: The booth on the left
i would just stick with the later part of being nicer to your wife. a little scrath on the inside of the truck no less is not a huge deal. no need to fret a bunch if it will only be visible to you.
#176216 - 06/04/01 11:15 AM
Re: First Scratch
Loc: New Jersey
Thanks for the recommendations.
If there is such a thing as a best place for a first scratch, this is it. I'll try to be more careful when closing the door...and nicer to my wife.
#176217 - 06/04/01 01:11 PM
Re: First Scratch
The match trick, that's with the "torn" end of a paper match, correct?
#176218 - 06/04/01 01:20 PM
Re: First Scratch
Originally posted by OffroadX: The match trick, that's with the "torn" end of a paper match, correct?
Brent yes that is correct. it works very well. i have to do it in quite a few places this weekend. ------------------ Synchro (aka Kirk) synchro@xterraoffroad.com 2000 Xterra SE, Alpine Green, 4x4, ARB, 32" BFG MTs
#176219 - 06/04/01 03:57 PM
Re: First Scratch
Always be nice to your wife  Leslie kicked a huge dent in the Xterra at our last Memorial Day party (I was bad and loaded up a porn DVD on the big screen while her family was here, my excuse was Jaegermeister). Somehow, she got a 1 ct. diamond ring out of the whole thing. The dent eventually sucked itself out as we left for GOX in July after loading up the X in the hot sun for 2 hours, then cooling it down with the AC. ------------------ Regards, Ian
#176220 - 06/04/01 06:21 PM
Re: First Scratch
Loc: Woburn, MA
Originally posted by BoarderPhreak: Best bet, get some touch up paint and apply it with a match, not the brush that comes with it. I've heard that mentioned before. A paper match right? What am I saying? A wooden one wouldn't work very well would it. And what else is there? Anyway, why a match. As I said, I've seen it mentioned. However I don't know the reason. Could you explain for those of us who have scratches, rock chips  , etc to fix? Pleeeaaase. ------------------ later, Rob 2000 Super Black SE 4x4, 5spd ========================= "not all those who wander are lost" -J.R.R. Tolkien
later, Rob
#176221 - 06/04/01 06:24 PM
Re: First Scratch
Loc: Woburn, MA
Originally posted by xoc: Always be nice to your wife
Leslie kicked a huge dent in the Xterra at our last Memorial Day party Ouch! I've known people to get divorced over less.  What's that saying? Hell hath no fury... ------------------ later, Rob 2000 Super Black SE 4x4, 5spd ========================= "not all those who wander are lost" -J.R.R. Tolkien
later, Rob
#176222 - 06/04/01 07:04 PM
Re: First Scratch
This happens to me a lot. I have reported it as a problem on the board but have never heard from anyone else with the problem. The seat belts twists when I take it off which prevents it from rolling up which means the buckle is hanging loose and gets stuck in the door when I slam it. Bummer. I am starting to remember to check but still a bummer.
------------------ Superblack 01 XE 5 Speed
#176224 - 08/04/01 09:20 PM
Re: First Scratch
Originally posted by fabien: The seat belts twists when I take it off which prevents it from rolling up which means the buckle is hanging loose and gets stuck in the door when I slam it. Try taking it off exactly how you put it on, but in reverse. Most of us are in a hurry, and unhook it, and let go of it while swinging a leg out the door. Unhook it, and hold it as it goes back up over your shoulder. It takes a few more seconds, but shouldn't end up in the door frame. ------------------ Regards, Ian
#176225 - 10/04/01 12:16 PM
Re: First Scratch
Loc: Huntington, NY
The brush usually holds too much paint. When it's applied, it forms a sort of "bubble" of paint, which will be too high compared with the surrounding paint.
The end of a match without the goop, that is, the torn end of a paper match... Holds just enough paint to dab in there.
The trick is to build up the paint, rather than have one big gloop of it. This way, later on you can just wax over the whole ordeal and it'll mostly disappear. Whereas if there's too much paint, you'd have to wet sand it down. The match also offers more control.
