230
#181357 - 06/08/01 11:34 AM
Roll-over Angle on the X
Loc: Calgary, AB, Canada
I've looked up the manual, I've searched this web-site, I've searched google, but I couldn't find anything relevant.
Does anybody know what the critical angle for roll-over is on the X?
In other words, on a stock X, without lift-kit, without accessories on the roof-rack, etc..., at what angle of sideways tilt does the X become unstable and prone to rolling over?
Thanks...
------------------ 2001 XE +pwr +auto Silver Ice (with a scar)
#181358 - 06/08/01 12:06 PM
Re: Roll-over Angle on the X
Loc: D/FW Metroplex, TX
I do not know that anyone has tried it out yet. I know that it depends upon your actions while in an offcamber situation. I think you can rollover at as little as 2-25 degrees. Oleg- How far off camber were you when it rolled?
------------------ Pains heal, Chicks dig scars, and glory lasts forever
Back in Network Administration! Bought a house, might get to play again soon!
#181360 - 06/08/01 02:05 PM
Loc: Arlington,TX USA
I just recieved a "Lev-O-Gage" from 4x4 Connection. Seven bucks. Bought one for Carlton and myself. That may be helpful if you are concerned about the angles. ------------------ John O'Polka2001 SE 4x4 Goldrush http://albums.photopoint.com/j/AlbumList?u=1435837&f=0
John O'Polka His and Hers Mustang GT's Extreamly modified! Big cams and NOS
#181362 - 07/08/01 08:40 AM
BTW, here's the link to Nissan Japan that shows the max roll for the Pathfinder/Terrano: http://www.nissan.co.jp/TERRANO/R50/9902/ENGINE/road.html Brent
#181363 - 07/08/01 05:27 PM
Loc: Woburn, MA
They even spelled out angle of approach (thank you Ian  ), departure angle and more. It'd be nice to get that mind of info on the X. [ 09-19-2001: Message edited by: 2kxtra ]
later, Rob
"not all those who wander are lost" -J.R.R. Tolkien
#181364 - 07/08/01 08:30 PM
Get yourself a nice piece of plywood and measure the angles yourself.
#181365 - 07/08/01 10:17 PM
Originally posted by 2kxtra: They even spelled out angle of attack, departure angle and more. It'd be nice to get that mind of info on the X.
http://www.nissannews.com/ (angle of "approach" BTW) ------------------ Regards, Ian
#181366 - 07/08/01 10:55 PM
Loc: Utah
I remember seeing this on the A/C board and wished they had that for the Xterra. I've been at some pretty serious angles but I want to know the limits too. Anybody willing to do some testing with their X?  ------------------ -Dustin War is Peace Freedom is Slavery Ignorance is Strength
#181367 - 08/08/01 04:24 AM
Loc: Brooklyn, NY
Originally posted by Kerensky97: [QUOTE] Anybody willing to do some testing with their X?
HELLLLLLLLLLLLLLLLL NO !  ------------------
#181368 - 08/08/01 10:10 AM
Loc: Grapevine, TX
Originally posted by xoc: Nissan does not make the information public for legal reasons.
I do know that the Pathfinder has a rated angle of 47 degrees static/parked/not moving.
I've had my Xterra at 38 degrees, and really wouldn't want to take it much further.
Well, Carlton and I were talking about that very thing last night and I figured it was pretty close to 36, so you made it farther than I thought feasible. That probably makes 36 a max roll number fairly close to real life for folks w/ roof mounted gear....I'm pretty sure I've been in the low 30's at least twice based on observation, and it was enough to get my attention!  ------------------ SWXC Mem.#1- www.swxc.org
'00 4wd SE Yellow 5 spd.
2012 4x4 S- work in progress....
#181369 - 08/08/01 03:28 PM
Loc: North Vancouver
According to that link Ian provided (nissannews.com), here are the stats:
4x2 4x4 XE SE XE SE ------------------------------- Minimum ground clearance 8.7 9.2 7.9 8.4 Angle of approach (in degrees) 29.8 30.9 29.6 30.7 Angle of departure (in degrees) 29.3 27.5 29.2 26.8
(edit) It looked better formatted when I typed it in, but you can figure out where the numbers go.
------------------ Jens I can't hear you lalalalalaa (runs with fingers in ears)
[This message has been edited by superjens (edited 08-08-2001).]
#181370 - 08/08/01 03:44 PM
Loc: Nashville, TN
Why are there differences between approach and departure angles from an XE and an SE. ACtually why are their differences between 4x2 and 4x4? In most cases I can understand the differences beteen 4 wheel drive and not, bc of diffent suspensions, but isnt the X the same accross the board? Isnt the limiting factor the front bumper and the rear tire? John
------------------ Silver Ice 4x4 Manual SE "An intelligent man is sometimes forced to be drunk to spend time with his fools"- Ernest Hemingway
"I STILL LOVE BEER!" -GOX III
#181371 - 09/08/01 07:11 AM
Originally posted by UTJMAC: Why are there differences between approach and departure angles from an XE and an SE. ACtually why are their differences between 4x2 and 4x4? In most cases I can understand the differences beteen 4 wheel drive and not, bc of diffent suspensions, but isnt the X the same accross the board? Isnt the limiting factor the front bumper and the rear tire? John
The only thing that I can think of is weight, but the difference is only 300 pounds between the 2WD and the 4WD. Perhaps the clearance difference is due to the transfer case/differential on the front. I have not looked that closely, but I assumed they were all as high as the front crossmember.  Now, the difference betweent he XE and the SE is the Sport Suspension.
#181372 - 10/08/01 02:20 AM
Loc: Milton, WI 53563
Think tires! 2001 XE 2wd had P235, XE 4WD (utility pkg required) has P265, SE has the oversize rims. That would have the most to do with it.
#181373 - 13/08/01 12:59 PM
Originally posted by Mobycat:
Sport Suspension? Is this something new? :p
The Sport package has slightly stiffer springs, and the SE comes with them standard.
#181374 - 13/08/01 02:05 PM
Loc: Forest Lake, MN
I wondered the same thing. I imagine it is different wheel/tire packages. Originally posted by UTJMAC: Why are there differences between approach and departure angles from an XE and an SE. ACtually why are their differences between 4x2 and 4x4? In most cases I can understand the differences beteen 4 wheel drive and not, bc of diffent suspensions, but isnt the X the same accross the board? Isnt the limiting factor the front bumper and the rear tire? John
#181375 - 13/08/01 09:42 PM
Griffin, what else do you have in your ass? The same springs and torsion bars are used all around. The only difference in the setup across any X is that the torsion bars on the 2WD models aren't cranked as far since they don't support as much weight.
#181376 - 14/08/01 01:52 PM
Loc: Charlotte, NC
the 4x4 weighs more... maybe that and the front differential have something to do with it.
The Van LIVES.
#181379 - 17/08/01 02:46 PM
Loc: walnut creek
Lets also take into account the KA24 motor vs. the VG33
Storm Trooper White 4 Banger
#181381 - 19/09/01 02:30 PM
Loc: walnut creek
I know my KA24 has a different differential.I wonder about the suspension.
