Problem posting?
11/06/24 10:33 AM
11/06/24 10:32 AM
0 registered (), 217 Guests and 0 Spiders online.
#188403 - 13/02/04 06:46 AM OBD code reader
warlock Offline
Loc: Springfield VA
Autobarn OBDII code reader
what do you guys think about this OBDII reader? will it work on our Trucks?
http://fotologue.jp/donnieandjemie/
#188404 - 13/02/04 07:03 AM Re: OBD code reader
ElectroKen Offline
Loc: Shelton, CT
The X is fully ODBII compliant and the reader in the link should work just fine. It is, however, only a reader.
What it won't do is allow you to monitor sensor data like a OBDII-to-PC interface will. Sensor data is only important if you want to repair the problem yourself.
Edited to repair the Ray Charles typing technique.
#188405 - 13/02/04 07:05 AM Re: OBD code reader
warlock Offline
Loc: Springfield VA
do you have an equipment that you could recommend?
#188406 - 13/02/04 07:39 AM Re: OBD code reader
ElectroKen Offline
Loc: Shelton, CT
If I were buying one today it would be this one:
click me
#188407 - 13/02/04 08:31 AM Re: OBD code reader
warlock Offline
Loc: Springfield VA
wow thats cheaper than the ones i have seen on the market. Do you think i should invest also on the BR-3 parts kit? I might as well
Thank You for answering my call for help
#188408 - 13/02/04 08:45 AM Re: OBD code reader
01SalsaXterra Offline
Loc: Suffolk County,NY,USA
That is awesome. I am looking into building and installing a Car-PC so I could get this and see the status of the drivetrain while driving on trips, etc. Kick Ass!!
Thanx for the link ElectroKen
I got "IT" from ebay.
Now it burns when I pee..
#188409 - 13/02/04 09:57 AM Re: OBD code reader
cygnus67 Offline
Loc: Southern NJ
I picked this one up last year. Works great and offer a bit more flexibility than most I've seen in the price range.
Auto Xray
Eagles may soar...but weasels don't get sucked into jet engines!
#188410 - 13/02/04 10:26 AM Re: OBD code reader
How do you advance the timing? I noticed the scanner lets you view the timing.
Also, does montoring the fuel system allow for calculating MPG on the fly calculation?
Dudes
#188411 - 13/02/04 05:46 PM Re: OBD code reader
Kerensky97 Offline
Loc: Utah
You can't change valve timing, ignition timing is pretty simple, loosen the screw at the base of the distributor and rotate the distributor by hand.
Check timing at bottom of the page .
-Dustin
Xterra101.com
#188412 - 16/02/04 08:30 AM Re: OBD code reader
rb42 Offline
Loc: McKinney
I've got an AutoX-Ray also, with the pc link (got the pro pack), and it's been great. Nissan vehicles won't give me as much data as Ford/Gm (I added the enhanced data options for those also), but it's still useable.
I got the Xray for a lot of different vehicles, not just Nissan, and I needed to read older ADL and ford codes aswell as new OBDII, so the Xray made sense.
It's constantly being updated too... Xray does a good job of keeping it up to date.
If you are just working on the one nissan truck, however, I'd buy something cheaper. I needed portability and convenience, and a wide range of compatibility.
-=RB
Moderator:  johngraves2
