I think this is it (I looked before he edited his post but didn't have time to reply):
http://www.autotrader.com/fyc/vdp.jsp?car_id=172470761 Is that it? If it is, I can tell you without a doubt that is the best year/color/model combo you can find anywhere - the only problem is the auto.
Anyway, seems like an ok price considering the mileage - it is $1000 less than bluebook - but you may be able to get it for a bit less.
One minor thing worth looking at is the steel under the back passenger seat - there is a braket mounted to the frame underneath that in some cases can get pushed up thru the steel. If it has done this, it should be pretty obvious, check for a small crack about 3-4" from the door and a couple of inches in front of the seat back. It's not a hard fix, but it can make for an annoying squeak. I ended up modifying the bracket and welding the crack, but if you point it out they could fix it for you.
