0 registered (), 104 Guests and 0 Spiders online.
#263714 - 29/08/06 08:14 AM Spongy brakes on the X ????
basic ? is.... is it as easy to bled the brakes ona car as it is on a motorcycle?
more in depth info
i had to replace the front brake pads on the X when they were well worn. In doing so i replaced them with some real thick pads reccommended for the X from autozone . To fit them in I had to push the pistons, with a vise grip on the calipers way back which in turn i had to open the brake fluid reservoir in the engine to allow the fluid to back up.
The next 3 days were fine , car braked great.
Now afer 3 weeks of not driving the car I get in and it seems as if the brakes are real spongy.
i figure i need to replace the brake fluid/ bleed the brakes.
Any other thoughts before i open this can of worms?? or use tidbits of advice before i do this?
did i do something incorrectly??
#263715 - 29/08/06 08:35 AM Re: Spongy brakes on the X ????
Try bleeding the brakes. It isn't very hard and only takes a few minutes to do it.
#263716 - 29/08/06 08:46 AM Re: Spongy brakes on the X ????
i would bleed the brakes which you already mentioned.
if you have 2 people its easier,(if you dont have a buddy to help with this process use a broom stick or a 2x4) but if you dont it can be done. i dont know if its the same as on a motorcycle, because i never had to do it to mine. anyways...
get the front end off the ground.(with wheel blocks and e-brake on)
remove both wheels
turn the steering wheel to the side you want to do first.
(i think it a 8 mil. closed end wrench for the bleeder vavle.)
pump the brake pedal five times. use either a buddy or a 2x4 to hold the pedal down.
release the bleeder valve (watch out cause its gonna fly)and then close it when the stream of brake fluid slows down.
i would do this twice to each side.
put everything back together, fill the brake fluid and take it for a spin.
#263717 - 29/08/06 11:13 AM Re: Spongy brakes on the X ????
sounds good... i have a mity vac so it shoudl make everythign easier i bet... hopefully this cures it..
#263718 - 29/08/06 02:36 PM Re: Spongy brakes on the X ????
confused
#263719 - 29/08/06 03:17 PM Re: Spongy brakes on the X ????
[b]... i have a mity vac
confused [/b]
This link explains it. It is a great tool for bleeding brakes if you want to spend the bucks.
http://www.trackhaus.com/brake-bleeder-3-ctg.htm?gclid=CKHoto_2hYcCFR1sWAodsDlAbQ
#263720 - 29/08/06 05:04 PM Re: Spongy brakes on the X ????
f%^& that, ill give my buddy a few beers, or my wife the best 5 sec of her natural born life before i spend $45 on some dumb shit like that.
#263721 - 03/10/06 06:19 AM Re: Spongy brakes on the X ????
conker69 Offline
Speaking of bleeding the brakes, the service manual (2002 Xterra) lists a bleed order of
Left Rear
Right Rear
Left Front
Right Front
Is this as if you're sitting in the drivers seat?? Is that the standard point of origin??
#263722 - 03/10/06 06:24 AM Re: Spongy brakes on the X ????
ATFrontier Offline
Loc: Loganville,Georgia
Drivers side is always the left side.
#263723 - 03/10/06 12:39 PM Re: Spongy brakes on the X ????
LMAO!!
5 seconds, huh? That's giving yourself a lot of credit...j/k
[Laughing] [Laughing] [Laughing]
#263724 - 03/10/06 02:20 PM Re: Spongy brakes on the X ????
[b]f%^& that, ill give my buddy a few beers, or my wife the best 5 sec of her natural born life before i spend $45 on some dumb shit like that.
LMAO!!
[Laughing] [Laughing] [Laughing] [/b]
thats what she said.
wink
[Spit]
