0 registered (), 433 Guests and 2 Spiders online.
#267419 - 15/01/02 02:56 PM 30X9.50R15C BF GOODRICH ALL TERR T/A KO
bobbyo Offline
Loc: rome ny
I am considering replacing my tires. I was thinking of mounting 30X9.50R15C BF GOODRICH ALL TERR T/A KO on my stock wheels. My X came with P265/70R15 110S BF GOODRICH LONG TRAIL T/A. wouldnt this tire mount easily without any modifications (ea trimming). i know a lot of people are mounting 31's but i really didnt want to cut any plastic. any advice pros and cons of the 30's. thanks for you help. smile
#267420 - 15/01/02 03:02 PM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
rrdstarr Offline
Loc: Tacoma
Do you have an 2002 or '01 or '00? I think the '02's are clearanced for 30" tires, but don't quote me! There mud flaps are shaped a little bit differently to allow "bigger" tires.
-Rick
#267421 - 15/01/02 03:12 PM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
bobbyo Offline
Loc: rome ny
Thanks for the prompt reply rrdstarr. I have a 2000 XE 4x4.
#267422 - 15/01/02 03:23 PM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
The 30" BFG is smaller than anything that came stock on the Xterra.
A little bit of trimming and a 31" would be a much better choice.
#267423 - 15/01/02 05:19 PM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
silverxglider Offline
Loc: Andes, NY
Anyone know exactly how much smaller/shorter the 30/9.5 BFG AT is than the stock 265/70/15?
I believe the stock tire is 29.6" tall.
Boldly going nowhere.
#267424 - 15/01/02 05:32 PM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Peanut Butter Offline
Loc: Vancouver, BC
Yes the 30 will fit with no trimming. I would go with the 31's. Only a little trimming needed and they look better.
#267425 - 16/01/02 06:33 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
lemsip Offline
Loc: Lakewood, CO
I was also reluctant to trim due to potential wife issues, but the amount you need to remove is very small.
Trim picture from Xterrain.com
2002 not needing trimming - from OffroadX
[ 01-16-2002: Message edited by: lemsip ]
#267426 - 16/01/02 06:57 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Dayspring Offline
Loc: Greenwood IN
Now, are the 2002 flaps able to be put on the 2000 models? How might that be accomplished? Only for the sake of my paint job...
#267427 - 16/01/02 07:55 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
defibvt Offline
7
Loc: AZ
Yes they can be put on a 2000 X. I have them on and I believe someone else does. You will have to some drilling of holes but all in all it took about 30 min to put them on.
#267428 - 16/01/02 08:27 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
EverythingZen Offline
Loc: Houston TX USA
The stock tires are all sidewall and the tread pattern on the 30" is wider. I had them and put them side by side with the long trails. Bigger seems to be better on this forum, that makes sense to some and doesn't for others.
--The difference between a warrior and an ordinary person is that the warrior sees everything as a challenge while an ordinary person sees everything as a blessing or a curse.--
#267429 - 16/01/02 10:39 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Scott Offline
Loc: Fort Collins, Colorado
I had the 30" BFG AT/KOs. Fine tire, but my rims are a lot more scraped up due to the narrowness of the tire. I went with the 31" BFG AT/KOs now and am much happier. Aside from the very minor plastic trimming there are no negative side effects. They are 1.2" larger in diameter than the 30" BFGs, so the extra .6" of ground clearance is nice. If you are just a poser they look better too!
#267430 - 22/01/02 09:05 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
cre8tor Offline
Loc: Ocean, NJ
What's the ?/? number for the 31" BFG AT/KOs?
I'm trying to find them at sears and I know nothing about tires.
Thanks,
“A man's only as old as the woman he feels.” - Groucho Marx.
#267431 - 22/01/02 09:28 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Zipper Offline
Loc: Drummondville, QC, Canada
cre8tor, they are 31x10.5 r15
Mik
#267432 - 22/01/02 09:35 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
cre8tor Offline
Loc: Ocean, NJ
Hmmm, they don't seem to have any that size -unless I'm doing something wrong.
Sears Tire Selector
#267433 - 22/01/02 09:43 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Dayspring Offline
Loc: Greenwood IN
In regards to the Sears thing, the website will show you tires that will fit stock... They don't like you putting 31" on there. Although, NJX was able to get them from Sears. So the ability to get them is not in question. It's their website that won't let you.
#267434 - 22/01/02 09:55 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
cre8tor Offline
Loc: Ocean, NJ
If you don't use the tire selector and just enter "BF Goodrich" in the search field it will return all the BFG's they have.
Which one is the 31 BFG AT/KO?
#267435 - 22/01/02 12:35 PM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Zipper Offline
#267436 - 23/01/02 06:22 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
cre8tor Offline
Loc: Ocean, NJ
Thanks!
#267437 - 24/01/02 12:04 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Takeabreath Offline
Loc: Indianapolis,IN
Originally posted by xoc:
[QB]The 30" BFG is smaller than anything that came stock on the Xterra.QB]
The Xterra came standard with 235 70 R15 Long Trails first year out, approximately 29.6".
"Dogs Love Trucks."
#267438 - 24/01/02 12:43 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Yes, and the BFG 30" All Terrain is 29.5" in diameter. Smaller than anything from the factory.
#267439 - 24/01/02 03:11 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Paul H Offline
Loc: Mt. Zion, IL
Drool damn this tire looks tuff. I can't wait for my grabbers to wear out.
My Blog
#267440 - 24/01/02 03:36 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Takeabreath Offline
Didn't mean for it to turn into this, but BFG AT smaller than a BFG Long Trail? Don't think so. I made a mistake in the actual diameter of the Long Trail; If it is a 235 70 R15, then the diamater is 28.1" and if it is a 235 75 R15 that equals 29.0" according to http://www.bfgoodrichtires.com/
"Dogs Love Trucks."
#267441 - 24/01/02 09:22 AM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Loc: Vancouver, BC
You think they look tuff you should see the mud tires eek.
Why wait? These tires are so much better then the stock ones even on road.
#267442 - 24/01/02 03:44 PM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
[QB]Didn't mean for it to turn into this, but BFG AT smaller than a BFG Long Trail? Don't think so.[QB]
You got me there, however, I have never seen an Xterra with weenie tires on it (the only way to get them is with an XE V6 with no packages, or a 4 cylinder).
Everything around here has the 265/70 tires, which are bigger than a 30" All Terrain.
[ 01-24-2002: Message edited by: xoc ]
#267443 - 24/01/02 03:59 PM Re: 30X9.50R15C BF GOODRICH ALL TERR T/A KO
Antitree_hugger Offline
Loc: Grandview, Wa
hhmmm mud tires. you mean like this?
