Problem posting?
Yesterday at 10:33 AM
Yesterday at 10:32 AM
0 registered (), 243 Guests and 2 Spiders online.
#270144 - 05/10/04 02:07 PM Good Read about CROSSDRILLED / SLOTTED rotors
stosh Offline
Loc: Pine Bush NY
Here is how it works. The friction between the pad and rotor is what causes you to stop. This friction converts your forward energy into heat (remember Einstein: Energy is neither created nor destroyed, it is converted). Now that heat is a bad thing. Yes it is bad for the rotors but it is a lot worse for the pads. A warped rotor will still stop the car - it will just feel like shoot. Overheated pads however WILL NOT stop the car. It is here where the rotors secondary responsibility comes in. Its job now is to DISSIPATE the heat away from the pads and DISPERSE it through itself. Notice that DISSIPATE and DISPERSE are interchangeable? Once the heat is removed from the pad/surface area it is then removed. Notice where the removal falls on the list of duties? That's right - number 3. Here is the list again. Memorize it because I will be using it a lot in this post:
#1 Maintains a coefficient of friction with the pad to slow the forward inertia of the vehicle
#2 DISSIPATE the heat
#3 REMOVE the heat from the brake system
Let's look more in-depth at each step now shall we? No? Too bad EXPLATIVE DELETED we are doing it anyway.
#1 Maintains a coefficient of friction with the pad to slow the forward inertia of the vehicle:
This one is pretty simple and self-explanatory. The rotor's surface is where the pads contact and generate friction to slow the vehicle down. Since it is this friction that causes the conversion of forward acceleration into deceleration (negative acceleration if you want) you ideally want as much as possible right? The more friction you have the better your stopping will be. This is reason #1 why BIGGER brakes are the best way to improve a vehicle's stopping ability. More surface area on the pad and the rotor = more friction = better stopping. Does that make sense Ace? Good. Let's move on.
#2 DISSIPATE The Heat:
Let's assume for a second that the vehicle in question is running with Hawk Blue pads on it. The brand doesn't really matter but that is what I am using as my example. They have an operating range of 400 degrees to 1100 degrees. Once they exceed that 1100 degree mark they fade from overheating. The pad material gets too soft to work effectively - glazing occurs. This means that a layer of crude glass forms on the surface of the pad. As we all know glass is very smooth and very hard. It doesn't have a very high coefficient of friction. This is bad - especially when I am coming down the back straight at VIR at 125MPH. Lucky for us the rotor has a job to do here as well. The rotor, by way of thermal tranfer DISSIPATES the heat throughout itself. This DISSIPATION lessens the amount of heat at the contact area because it is diluted throughout the whole rotor. The bigger the rotor the better here as well. The more metal it has the more metal the heat can be diluted into. Make sense? This isn't rocket science here d00d.
#3 REMOVE the heat from the brake system:
Now comes your favorite part of the process. This is what you thought DISSIPATION was. It is ok. I will allow you to be wrong. This is the step where the rotor takes the heat it DISSIPATED from the pads and gets rid of it for good. How does it do this? By radiating it to the surface - either the faces or inside the veins. It is here where cool air interacts with the hot metal to cool it off and remove the heat. Once again there is a reoccuring theme of "the bigger the better" here. The bigger the rotor, the more surface area it will have which means more contact with the cooling air surrounding it. Got it? Good.
Now let's look at why cross-drilling is a bad idea.
First - as we have already established, cross-drilling was never done to aid in cooling. Its purpose was to remove the worn away pad material so that the surfaces remained clean. As we all know this doesn't have much of a purpose nowadays.
Next - In terms of cooling: Yes - x-drilling does create more areas for air to go through but remember - this is step 3 on the list of tasks. Let's look at how this affects steps 1 and 2. The drilling of the rotor removes material from the unit. This removal means less surface area for generating surface friction as well as less material to accept the DISSIPATED heat that was generated by the friction. Now because of this I want to optimize step one and 2 since those are the immediate needs. If it takes longer for the rotor to get rid of the heat it is ok. You will have a straight at some point where you can rest the brakes and let your cooling ducts do their job. My PRIMARY concern is making sure that my car slows down at the end of the straight. This means that the rotor needs to have as much surface as possible to generate as much friction as possible and it needs to DISSIPATE the resulting heat AWAY from the pads as quick as possible so they continue to work. In both cases x-drilling does nothing to help the cause.
Now let's talk about strength - and how x-drilled rotors lack it. This one is simple. Explain again just how drilling away material/structure from a CAST product DOES NOT weaken it? Since you are obviously a man of great knowledge and experience surely you have seen what can happen to a x-drilled rotor on track right? Yes it can happen to a non-drilled rotor as well but the odds are in your favor when pimpin' bling-bling drilled y0! Since you are also an expert on thermodynamics why not explain to the group what happens to a cast iron molecule when it is overheated. I will give you a little hint - the covalence bonds weaken. These bonds are what hold the molecules together boys and girls. You do the math - it adds up to fractures.
So why don't race teams use them if they are so much better? Consistency? Hmmmm . . . no. I am gonna go with the real reason her chodeboy. It is because of several factors actually. They are as follows but in no particular order:
- Less usable surface area for generating friction
- Less material to DISSIPATE the heat away from the pads
- Less reliable and they are a safety risk because of fatigue and stress resulting from the reduced material
And what are the benefits? Removal of particulate matter and enhanced heat removal. I gotta tell ya - it is a tough choice but I think I am going to stick with the safe, reliable, effective-for-my-stopping needs solution Tex.
I pump CAD
#270145 - 05/10/04 02:08 PM Re: Good Read about CROSSDRILLED / SLOTTED rotors
stosh Offline
Loc: Pine Bush NY
http://www.teamscr.com/rotors.htm
More info some duplicate.
I pump CAD
#270146 - 07/10/04 11:23 AM Re: Good Read about CROSSDRILLED / SLOTTED rotors
stosh Offline
Loc: Pine Bush NY
man I thought people would eat this up... as in like it and respond...
I pump CAD
#270147 - 07/10/04 12:17 PM Re: Good Read about CROSSDRILLED / SLOTTED rotors
Happy with my stock brakes, thank you. Don't need drilled or slotted rotors giving off-road crud an easier way in between the rotor and pad...
#270148 - 07/10/04 01:23 PM Re: Good Read about CROSSDRILLED / SLOTTED rotors
I thought there would be a lot of conversation about it also. Those types of rotors are mostly for sports cars though.
#270149 - 07/10/04 01:35 PM Re: Good Read about CROSSDRILLED / SLOTTED rotors
stosh Offline
Loc: Pine Bush NY
Thats what the article is about. It just seems to me that there was a lot of people going to slotted and cross drilled. Anyway I thought the article was interesting and some people would see that there is no difference so why pay more.....
I pump CAD
#270150 - 07/10/04 01:36 PM Re: Good Read about CROSSDRILLED / SLOTTED rotors
stosh Offline
Loc: Pine Bush NY
I did a search for rotors on here and it seemed like a lot of people were looking into buying slotted or crossdrilled for their xterra.
I pump CAD
#270151 - 07/10/04 03:10 PM Re: Good Read about CROSSDRILLED / SLOTTED rotors
I am looking at slotted.. the cross drilled will remove what, 8 maybe 10 oz off each rotor.. may be worth somthing on a spors car, but with 31" to 33" rubber on our trucks, you will never notice it..
The slots should help keep the pads clean, by removing whatever gets stuck between the pad & rotor..
#270152 - 07/10/04 03:35 PM Re: Good Read about CROSSDRILLED / SLOTTED rotors
DocNo Offline
Loc: NoVA
? The X isn't a sports car, nor do I drive it like such (that's what the Miata is for).
The X has one of the best stock braking systems of it's class. Unless you were towing something heavy down a steep grade and not using engine braking, I would be suprised that you could overheat the stock braking system enough to notice a loss in performance.
Heck, the stock Miata brake system has to be thoroughly abused at the track to induce overheating.
Slotted rotors do allow water/mud to clear faster, but I see people here mowing through mud and water all the time.
That's probably why there hasn't been much of a response...
Murderous Fire!
#270153 - 07/10/04 05:02 PM Re: Good Read about CROSSDRILLED / SLOTTED rotors
The article is in every way true. You are risking a lot when putting on drilled rotors. Here's the thing: it was/is popular in the "rice" market and I saw a lot of people put on drilled rotors. But what you guys don't know probably, is a lot of those guys cracked their rotors and it wasn't done just on track! Some people did that after about 20 minutes of heavy braking at stop lights (such as when you are racing someone on the street or showing off). Why it happened? Because most of them could not affor Brembos or any other high quality brake system and when with a cheaper alternative. You get what you pay for. Now, for those Cross drilled AND slotted rotors...don't get me started on that.
#270154 - 07/10/04 11:26 PM Re: Good Read about CROSSDRILLED / SLOTTED rotors
I put X-drilled rotors on my prelude when I was young and naive. [Finger] Shortly thereafter, I warped them. (mainly from reasons you described)Never again.
However, the main reason I got them was because I was under the impression that the X-drilled rotors allow the gases created from braking to exit. If there is a layer of gas between the rotor and pad, it would contribute to brake fade, and low friction. [Uh Oh !]
#270155 - 08/10/04 06:32 AM Re: Good Read about CROSSDRILLED / SLOTTED rotors
stosh Offline
Loc: Pine Bush NY
Funny thing was the day after I bought x-drilled Brembo rotors for my solara I read the above articles.
I must say that due to the quality pads I installed as well I have noticed a huge change from stock. Who knows why though.
I pump CAD
