0 registered (), 46 Guests and 0 Spiders online.
#27207 - 29/03/06 02:38 PM Antifreeze odor
Checked search but nothing.
I have a 03 4x4 Xterra with 27k miles. Upon start up there is an odor which smells like anti-freeze. Once I drive it seems to go away. There are not leaks anywhere in or outside the car. Could this be common or is something bad going to happen soon? Thanks!
#27208 - 29/03/06 02:40 PM Re: Antifreeze odor
Hmm, Have it pressure checked ICE COLD! Mine was a radiator. Once it warmed up, everything sorta filled in and wouldnt leak.....
M
#27209 - 29/03/06 03:21 PM Re: Antifreeze odor
Where did you search?
Problems/annoyances section:
http://www.xterraownersclub.com/ubb/ultimatebb.php?ubb=get_topic;f=45;t=000743
http://www.xterraownersclub.com/cgi-local/ultimatebb.cgi?ubb=get_topic;f=45;t=000776
http://www.xterraownersclub.com/ubb/ultimatebb.php?ubb=get_topic;f=45;t=000812
http://www.xterraownersclub.com/ubb/ultimatebb.php?ubb=get_topic;f=45;t=001753
http://www.xterraownersclub.com/ubb/ultimatebb.php?ubb=get_topic;f=45;t=002010
#27210 - 29/03/06 06:54 PM Re: Antifreeze odor
Thanks. Not sure why I didnt find anything. confused
It looks like this is a common problem. I guess I will further observe my coolant level and see what is going on and if there are any small leaks.
#27211 - 30/03/06 07:48 AM Re: Antifreeze odor
Kaiser Offline
If you smell it - there is a leak. It's probably just really small right now and hard to find.
A few people have had problems with leaks that leak onto the manifold - so it burns off and you never see anything on the ground.
Polish up your detective hat and be persistent laugh
I had a post-drive smell recently that turned out to be a clamp that wasn't quite tight enough on my upper radiator hose. My power steering hose clamps just gave out as well. It's not a bad idea to just start systematically replacing all the crappy factory clamps (especially the stupid spring-tension ones that don't even have a screw to tighten them) with the old-school screw type.
ETA - there is also a TSB somewhere about coolant smell - there is some gasket in the thermostat area that goes bad on some vehicles... anyone know what the hell I'm talking about?
#27212 - 30/03/06 10:22 AM Re: Antifreeze odor
Yah, intake manifold water outlet gasket.
http://www.nissanhelp.com/Ownership/Bulletins/Nissan/2002/NTB02-044.htm
Now can we move this to the P&A section for the next person to find?
