0 registered (), 109 Guests and 0 Spiders online.
#275284 - 16/03/01 09:49 PM tire size and lift
STEPH Offline
Loc: Gatineau, Quebec , Canada
Hi yall !
Staight out , I`m a Jeep guy . My wife fell in love with the the XTERRA the day she saw it for the first time.
3 weeks ago , she got 2001 4x4 auto tranny solar yellow Xterra SE with a black WAAG push bar.
I must say I`m very impressed with the ride and looks of it .
personnally, I`m driving a 99 TJ Sahara with a 5 inch lift and 33" tires and all the goodies and I kinda want the X to gain a little height or a least look a little beefier while retaining a sober look.
Well , as sober as a solar yellow X can get.
So , my questions are ;
1.Those 255/65-16 have gotta go. a low profile tire on a s.u.v... No Way ! So what tire size can I put on without lifting it ? I was thinking maybe 265/75-16
2. Will a tire this size affect engine performance. b.t.w , what is the axle gearing in these things ?
3. Knowing that a shackle lift will usually kill any soft riding leaf spring like the ones on the X within a year or two since it puts most of the weight of the vehicle on the back half of the spring pack , How do the springs hold on with longer shackles ?
4. Not being familiar with torsion bars , how much can I crank them before I feel any adverse effect or a rougher ride ?
5. How does Nissan feel about longer shackles , cranked torsion bars and larger tires ? I thought Nissan was very severe as far as the warranty goes. I heard that they will void the warranty if you only put larger tires!
I know that`s a lot of questions guys , but I must say I`m very pleased to see that not only Jeep guys are proud of what they drive.
So now I guess I can have the best of both worlds !
Oh ya , What`s that neat looking basket that some of you have mounted on the roof rack ?
Thanks in advance for your help .
Steph.
#275285 - 16/03/01 10:16 PM Re: tire size and lift
defibvt Offline
7
Loc: AZ
I don't know the answers to your questions but with a little searching with the search engine you could probably have a lot of them answered.
There are only three sports-Mountain climbing, bullfighting, and motor racing-all the others being games. --Ernest "Papa" Hemingway
#275286 - 16/03/01 10:41 PM Re: tire size and lift
1. the 255/65 isn't really what I would call low profile, it has a taller sidewall than anything on a stock Jeep. 1 265/75-16 will put you at 31.6" which will fit with some modifications to the plastic trim around the wheel wells.
2. Oversizing a tire on any vehicle will decrease performance. Your SE should be geared at 4.636 ring and pinion. The Xterra is weak in the transfer case, with only a 2.01:1 low range ratio.
3. I'm on my second set of springs in 20 months, and they have already sagged 2 inches in 6 months. I'm looking for a better solution.
4. About an inch. Get a factory manual if you want to keep it within specs.
5. No problems yet.
Regards,
Ian
#275287 - 29/03/01 02:31 AM Re: tire size and lift
DGX Factor Offline
Loc: Denver, CO
What do you mean by cutting the plastic. Are you refuring to the mud flaps
#275288 - 29/03/01 08:32 AM Re: tire size and lift
BoarderPhreak Offline
Loc: Huntington, NY
That's what he means.
The mudflaps must be trimmed.
#275289 - 29/03/01 10:50 AM Re: tire size and lift
swampwrecker Offline
Loc: Brunswick, GA
I fit 33x10.50 Super Swampers under my X with just a little adjustment of the torsion bars and a little trimming.
Wow, you needed 5" of Lift to get 33s under the TJ, that's a bummer.
Michael Girardo
Member - MAXC | Moderator - XOC
www.avaloninternet.net/users/bythebay/xterra <---Redesigned
Michael Girardo
East Coast Xterra Challenge
swampwrecker@ecxc.com
