#280541 - 28/08/06 05:52 PM Excessive ballancing required
Greetings,
Not new to the board, just can't find log-in info anymore. On to my question, I bought 265/65/17 Bridgestone dueler H/T's about 1 year ago, I've had to ballance them about 6 times now, and still my fillings are being rattled out of my teeth. Does anyone know how I can fix this or at least determine what is going on with these tires...I should have known better than to buy cheap tires.
#280542 - 28/08/06 08:48 PM Re: Excessive ballancing required
did you (or anyone else) EVER put ANYTHING into the tires, other then air/co2? Like the liquid Fix-a-flat.. or ANYTHING else?
I had a tire I "fixed", and it wouldn't balance afterwards.. had to drain & scrub all the green stuff out before it would balance.
#280543 - 29/08/06 04:36 AM Re: Excessive ballancing required
marmillerX Offline
Loc: Shrewsbury, MA
You also might want to check out your U-joints. I had the same problem and the tire place kept telling me it was my tires but I found that I had a worn U-joint. Just my $.02 good luck
#280544 - 29/08/06 08:04 AM Re: Excessive ballancing required
Thanks for the advice...never put anything into the tire, shake started as soon as I had tires installed, I have had three different places ballance the tires, all seemed to agree they where out of ballance...all was smooth for about 100-200 miles and then same issue again. Could changing tires affect u-joints...asking beacuse problem was never evident with old tires. I googled my tires and this seems to be an issue with these tires...any recomendations of new tires? Michelin's seem expensive but do receive high praise.
#280545 - 29/08/06 08:12 AM Re: Excessive ballancing required
ATFrontier Offline
Loc: Loganville,Georgia
Tires could be out of round in which case they will never balance unless they were shaved where needed. Just take them back where you bought them.
