Page 2 of 2 < 1 2
#288088 - 19/11/02 12:57 AM Re: What Kind of Stereo and Amp Set-Up Do You Have?
Griffin2020 Offline
Loc: D/FW Metroplex, TX
There are not holes in the rear doors, but it is easy (with a dremel or similar tool) to cut some.
My setup is similar to Pino's (at least the rear door speakers), except I simply got a pair of shallow speakers and installed them directly to the plastic on the lower part of the door. If you remove the trim piece, you will see there is a hole that the magnet (driver) will fit into, if it is shallow.
Back in Network Administration!
Bought a house, might get to play again soon!
#288089 - 19/11/02 07:20 AM Re: What Kind of Stereo and Amp Set-Up Do You Have?
Bobby_X Offline
Originally posted by gearhead1972:
Originally posted by Bobby_X:
[b]I still think about mounting the amp upside down in the cargo-area.
Mounting an amp upside down is not a good idea the heat has no way of dissipating from the heat sink that way and will cause thermal shut down and possible damage[/b]
Hmm.. This sucks to hear frown Would there be anyway around this? I realize that heat rises. Do you think all the open room in the X would help this out? I don't want to toast an amp though.... Man!! dangit!
#288090 - 19/11/02 07:22 AM Re: What Kind of Stereo and Amp Set-Up Do You Have?
p.i.n.o. Offline
Loc: Sugar Land, TX
Originally posted by JamesP32750:
Great Pics! The carpet trim on the rear doors, was that standard or added with the speaker update?
I built the kick panels on the rear doors with the help of a friend. I originally covered the panels in black vinyl but it did look as good as I thought it would, so I used the grey will you see in those pictures. If you're interested, I can post some pictures of the panel's build up.
#288091 - 19/11/02 07:37 AM Re: What Kind of Stereo and Amp Set-Up Do You Have?
XterraDiver Offline
Loc: Monterey, CA
[b]
Hmm.. This sucks to hear frown Would there be anyway around this? I realize that heat rises. Do you think all the open room in the X would help this out? I don't want to toast an amp though.... Man!! dangit![/b]
I would think that if you added an Xternal fan to blow out the heat, you could mount it upside down. I have seen several models on the net.
My other truck is an Ambulance
www.scubadivervideo.com/xterra.htm
#288092 - 19/11/02 12:12 PM Re: What Kind of Stereo and Amp Set-Up Do You Have?
Griffin2020 Offline
Originally posted by XterraDiver:
[QB
Mounting an amp upside down is not a good idea the heat has no way of dissipating from the heat sink that way and will cause thermal shut down and possible damage[/qb][/QUOTE]
If you mounted it OUT IN THE OPEN, whther it was inverted or not, should not affect the operation. If, however you covered the heatsink, then it would affect it (overheat, etc.). The orientation of the heatsink does not affect its operation, it would still disipate into the surrounding atmosphere. Yes, heat rises, but heatsinks operate on the theory of disipation through radiation by way of surface area.
#288093 - 06/12/02 02:33 PM Re: What Kind of Stereo and Amp Set-Up Do You Have?
bronx Offline
Loc: California
Got carried away with whole X-Factor Thing
Optima: YellowTop
Sony: CDX 600M
Front : Lanzar 6.5" w/ stock tweeters
Back Door: Sony Xplod 6.5"
Cargo Area: Lanzar 6x9"
2 - 10" MTX 6000
Sony 10 Disc CD Changer
Sony AMP 1002HX 400Watts
Sony AMP 4CH 460 Watts
3 - 5.6" XO Vision
Boss DVD Player [DVD2000]
Click Here
http://www.cardomain.com/ride/2327321
#288094 - 07/12/02 10:19 AM Re: What Kind of Stereo and Amp Set-Up Do You Have?
Sean Offline
Loc: Billerica, MA
I'm running:
Fronts - 6.5" Polk MOMO MM6 components
Rears - Alpine 6x9 SPS6939S 3-way
Sub - JL 10W3V2-D2 10"
Amp - JL 500/5
Deck - Alpine 7995
Monster 1 Farad Capacitor
http://www.grovestreet.com/jsp/onepic.jsp?id=144972
http://www.grovestreet.com/jsp/onepic.jsp?id=131239
http://www.grovestreet.com/jsp/onepic.jsp?id=118467
Ned Flanders: "Some people say being a cave man is old fashioned, then I guess I'm just a cave man...if they existed....which they didn't."
My Former 2001 Xterra SE 4x4 With Modifications
My Ex-Xterra Web Site
#288095 - 14/12/02 08:15 PM Re: What Kind of Stereo and Amp Set-Up Do You Have?
Hotwhlz Offline
sounds like a tweeter install sean.
#288096 - 15/12/02 05:45 AM Re: What Kind of Stereo and Amp Set-Up Do You Have?
Sean Offline
Loc: Billerica, MA
Tweeter in NH made the custom sub box, Circut City installed the capacitor, and I installed the speakers and the deck. I tried to get the JL Audio 500/5 amp, and the Polk MOMO MM6 component 6.5" speakers on eBay (like the Alpine 7995 deck $350, and the JL 10W3V2-D2 sub $115), but I couldn't find any. I ended up buying the Polk's at Circut City on sale for $220 something.
Page 2 of 2 < 1 2
