0 registered (), 268 Guests and 0 Spiders online.
Page 2 of 7 < 1 2 3 4 5 6 7 >
#288504 - 11/07/02 06:05 AM Re: Intermittent rear wiper
dmolavi Offline
Loc: Atlanta, GA
is there a way someone could get their hands on the '02 rear wiper motor assembly (shop, etc) and just bench test it on that before tearing apart the rear hatch of your X?
dm
"Eat a live toad the first thing in the morning and nothing worse will happen to you the rest of the day."
Got a question? You used to be able to ask Brent , but not anymore...
#288505 - 11/07/02 07:41 AM Re: Intermittent rear wiper
intron Offline
Loc: South Carolina
electroken,
ah.. i get it now..that makes sense and seems like the easiest way to do it. let me know what you come up with and maybe i can convince my wife (we all have to answer to someone) to let me install it. thanks.
#288506 - 11/07/02 09:19 AM Re: Intermittent rear wiper
ElectroKen Offline
Loc: Shelton, CT
dm
The device will attach to the wiring harness under the dash. There will be 3 connections:
1) power
2) ground
3) a connection to the blue/yellow wire on the rear wiper switch.
This all assumes that the 2002 rear wiper switch is the same as in my 2000. If it isn't, someone should let me know soon.
#288507 - 11/07/02 12:58 PM Re: Intermittent rear wiper
NIXTERRA Offline
Loc: Ontario, Canada
Just for your information....
I used to have a '98 Pathfinder, before I switched to my X.
In the Path, they had a three way (off, int, and full on) If there is some way of taking that switch, and using the delay realy or motor from the Path and hooking it up to the X...
I'd be all over that!!
- Nik
Always be more curious than afraid.
#288508 - 11/07/02 08:57 PM Re: Intermittent rear wiper
intron Offline
Loc: South Carolina
electroken,
well... i went under there and tried to take a picture but it looks like hell. you can still go see it if you want:
http://home.sc.rr.com/mroberts/wiper.jpg
It isn't worth putting inline and wasting everyones bandwidth.
the bottom line is that there appeared to be 3 wires into the top of the switch and three to the bottom. there was a pink one. a blue one with a reddish line down it and a black one (that i think had white polkadots but it is late and i could just be seeing things in the dark)
i hope this garbled bunch of info helps some.
#288509 - 16/07/02 07:54 AM Re: Intermittent rear wiper
Staubers Offline
Loc: Summerville SC
Went to the dealer today..was told instruction manual and window sticker is a miss-print confused No intermittent option on the 2002 model..ElectroKen, help!!
I'm a HEATHEN!?
#288510 - 16/07/02 09:23 AM Re: Intermittent rear wiper
ElectroKen Offline
Loc: Shelton, CT
I have several versions of the circuit drawn up. The versions differ only in the way that the operator contols the delay. Which should I make first?
1) A fixed delay with only a small switch to activate or deactivate the circuit. The delay interval would be set by the installer at the time the box was installed. The 2000 X has a fixed delay.
2) A variable delay with a single knob to both turn the unit on and set the delay (like the volume control on an old car radio).
3) A variable delay with a small switch to activate/deactivate the unit and a separate knob to control the delay. This allows the delay setting to remain set when turning it on or off. It will also look more cluttered.
It would also be a plus if anyone can get me a 2002 wiring diagram for the rear wiper circuit. Without it I have to make some assumptions that may be wrong.
#288511 - 16/07/02 11:08 AM Re: Intermittent rear wiper
Staubers Offline
Loc: Summerville SC
I would opt for option 1, all I'm looking for is a sweep about every 10 seconds. I would not even want a continuous motion at all. As far as the diagram..I will do a little hunting laugh
I'm a HEATHEN!?
#288512 - 16/07/02 11:52 AM Re: Intermittent rear wiper
dmolavi Offline
Loc: Atlanta, GA
ditto, a 10 second sweep would be nice.
#288513 - 17/07/02 06:22 PM Re: Intermittent rear wiper
lboogie Offline
Loc: FlaVAtown
I'll double check my '02 X. I could swear mine is intermitent, but maybe I'm not remembering correctly.
I know for a fact that it does have a delay. I got mine back in August of last year. Wonder if they made some changes in the units they produced this year?
I'll post my findings.
/;0\
How do you know where I'm at when you haven't been where I've been, understand where I'm coming from?
#288514 - 17/07/02 07:23 PM Re: Intermittent rear wiper
x_jay Offline
Loc: Medina, OH
Its good to know I am not the only one who hates the constant wiping. I always just turn it on for one wipe when i need it, becuase the constant wiping drives me crazy, and I have never been in weather that requires constant wiping. Its my only fault with the X. You could easily put a delay switch on the power wire, I am just not sure if that would be good for the wiper's motor. Well I guess I will just keep flipping the switch on and off.
#288515 - 17/07/02 08:05 PM Re: Intermittent rear wiper
Xterradon Offline
Loc: Franklin Park, NJ
Why would putting a delay-relay be bad for the motor? It's seems as though it would be the same as you clicking the switch on and off manually. I'll try to locate such a relay. Question is, what is the amperage going to the motor?
-Bryan
#288516 - 18/07/02 02:56 AM Re: Intermittent rear wiper
ElectroKen Offline
Loc: Shelton, CT
It can't be too bad for the motor - the front wiper is already intermittent.
Our rear wiper motor is the same as most have been for decades. To start a wipe, you complete the ground side of the circuit. After the wipe starts, a contact within the motor completes the ground side of the circuit until the wiper reaches its home position again. The internal contact then opens.
All any delay circuit needs to do is to ground the motor lead for about a half-second to start the process. The simple circuit I am building grounds the wire for 0.5 seconds and then opens it for 9.5 seconds. The motor does the rest.
#288517 - 18/07/02 12:47 PM Re: Intermittent rear wiper
ElectroKen Offline
Loc: Shelton, CT
Progress!
The software for the delay circuit is done (I think). I'm using a microcontroller because it's smaller and cheaper now than any of the old analog approaches. Check out the massive computing power:
4 MHz clock
0.001 Meg ROM
0.0001 Meg RAM
Yeah, baby.
#288518 - 18/07/02 10:24 PM Re: Intermittent rear wiper
*paul Offline
Loc: New Zealand
You mean the '555 is dead?
-Paul
2007 Nissan X-Trail
New Zealand (ex San Diego)
#288519 - 19/07/02 02:57 AM Re: Intermittent rear wiper
ElectroKen Offline
Loc: Shelton, CT
The good old '555 timer IC is still alive and well. The oldest IC I own is a NE555 from 1973. It's a great part but for longer time delays the capacitors used with it get large and inaccurate.
I stopped using 555s as timers when the price of an 8-pin microcontroller with an internal oscillator came down to $1. I'm just a digital kind of guy. cool
#288520 - 23/07/02 10:16 AM Re: Intermittent rear wiper
dmolavi Offline
Loc: Atlanta, GA
how's this gizmo coming along?
#288521 - 23/07/02 05:29 PM Re: Intermittent rear wiper
ElectroKen Offline
Loc: Shelton, CT
I finished the first delay circuit today. The first goes to Staubers, the first to volunteer as a guinea pig. The first one is a freebie - we're not even sure that the 2002 wiring will accomodate it yet.
It is a small box, 1.7" X 1.5" X 0.9" with 3 wires. It will come set to 10 seconds but can be adjusted anywhere from 1 second to 20 seconds with a small screwdriver.
#288522 - 23/07/02 06:23 PM Re: Intermittent rear wiper
Xterradon Offline
If it works, will it be mass marketed?
-Bryan
#288523 - 23/07/02 06:52 PM Re: Intermittent rear wiper
ElectroKen Offline
Loc: Shelton, CT
Sure, if "mass marketed" means a couple dozen. I'd go nuts building any more than that. [Freak]
I'll also make the schematic and parts list available to anyone that wants to build their own.
#288524 - 24/07/02 02:12 AM Re: Intermittent rear wiper
Origami Gangsta Offline
Loc: Dammit! Even CLOSER to Smith a...
Electroken strikes again! Dude, you ARE the man.
Sven, let's dig into yer truck over a couple beers, maybe next weekend?
This is how you post whore..
#288525 - 24/07/02 05:26 AM Re: Intermittent rear wiper
Staubers Offline
Loc: Summerville SC
Originally posted by TatsuoX:
Electroken strikes again! Dude, you [b]ARE the man.
Sven, let's dig into yer truck over a couple beers, maybe next weekend?[/b]
I could do that, first I should contact Electroken and see how this item will get to my house...
Edited to add, sent PM to Electroken. Tats I'm guessing you and I will be doing a little electrical work 3 or 4 August BBQ again?
I'm a HEATHEN!?
#288526 - 24/07/02 11:25 PM Re: Intermittent rear wiper
The 4th sounds excellent to me!(I'll definitely get that day off.)
BBQ also sounds excellent again! More chowpau(sp)? :p
#288527 - 26/07/02 07:44 AM Re: Intermittent rear wiper
lboogie Offline
Loc: FlaVAtown
OK so it rained today. I turned on the rear wiper and sure enough a 10 second delay between wipes. For me that's intermitent, I'm happy with it.
/;0\
#288528 - 30/07/02 02:12 PM Re: Intermittent rear wiper
Staubers Offline
Loc: Summerville SC
Just wanted to say I received the delay today, ElectroKen is the man. Install looks simple, Tats and I should get this done easy this Sunday. Update on Monday...
Would like to add that this little black box looks extreemly professional...Some high quality stuff.
I'm a HEATHEN!?
