0 registered (), 120 Guests and 1 Spider online.
#290285 - 30/10/04 10:26 AM Amp install
Hey all-
this is my first time completely doing an amp install myself, everything has gone very well. there is only one thing that i am having problems with. i have grounded the negative, and run the positive to the battery.
NOW, the third wire, which is the small on off sensor, where do i plug that in? i figure on the back of the deck, but does anyone know which wire it goes into? or am i wrong?
THANK YOU!
#290286 - 30/10/04 04:50 PM Re: Amp install
Rickster43 Offline
Loc: San Antonio,Texas
Don't know the answer to your Question, but I am replying cause I am curious of what location inside your X did you put your Amp at?...I am thinking about getting an Amp for my System also
Your Personal CADD Monkey...
#290287 - 30/10/04 04:51 PM Re: Amp install
If you don't have an aftermarket radio, you need to connect it to a 12v switched wire(meaning it turns on and off with the key) either behind the radio or on the fuse box. If you do have an aftermarket, it needs to go to the remote amp turn-on on it's wiring harness.
#290288 - 30/10/04 06:52 PM Re: Amp install
I mounted it to the back of the passanger side, rear seat. I wanted to put it under the passanger seat, but it didnt fit without raising the seat, and i didnt want to do that.
#290289 - 30/10/04 06:53 PM Re: Amp install
ok... its an aftermarket, pioneer deck. i will look at the wiring diagrams to try to find the right one...
thank you
#290290 - 30/10/04 07:27 PM Re: Amp install
it's usually the blue wire w/ a white stripe or it's tagged as "remote wire"
#290291 - 31/10/04 04:51 PM Re: Amp install
thanks man... the wire you described was the right one! its always nice when you put something together, and it actually turns on at the end...
thanks to all
#290292 - 02/11/04 12:00 PM Re: Amp install
[Wave] [ThumbsUp]
