0 registered (), 125 Guests and 0 Spiders online.
#290897 - 07/07/04 11:29 PM dash light dimmer
I didn't really know what I was doing, but I went ahead anyway and installed myself a new deck. I hooked my iPod up to it and everything works great except that at night my dash board blinds me because the instructions for installing the stereo did not say what to do with the wire for the dimmer switch. The new deck doesn't have a wire with which to attach the dimmer wire to so I am at a loss. If anyone could let me know what to do, that would be great, thanks.
#290898 - 12/07/04 11:02 PM Re: dash light dimmer
if someone could help me out that would be awesome... i would like to fix this problem before my parents find out frown
#290899 - 12/07/04 11:59 PM Re: dash light dimmer
What head unit did you put in (specific model number) and what wire harness did you use?
You DID use a harness....didn't you?????
#290900 - 13/07/04 06:44 AM Re: dash light dimmer
what problem do you have?
do you mean the face of the new radio is too bright at night?
or does the dimmer switch not work anymore?
if the new radio does'nt have a wire to attatch to the dimmer wire,then just tape the end of the wire so it does'nt short and everything will work normally in the vehicle.
#290901 - 13/07/04 05:59 PM Re: dash light dimmer
i have a rockford fosgate x8350 and i just used the harness it came with. my problem is that when i turn the headlights on, the speedo and stuff are full brightness and turning the dimmer switch does nothing. the wire for the dimmer that came out of the old h/u is just floating around back there, cause there is nowhere to attach it to the new harness.
