208
#294512 - 07/06/02 11:18 AM
Re: DIN Output - 2000 XE Radio
Loc: Vancouver, BC
Maybe I'll see if Richard Krenn can pass along the info to me. I know it's only $20, but like you I am trying to do this as cheap as I can. I have already bought a whole bunch of parts for my mp3car that I've had to throw away cause they didn't work as expected and when you buy everything from the US, it tends to add up to quite a bit.
So if Richard Krenn could help me out by either describing the schematics or sending me scans of them it would be GREATLY appreciated. If he isn't able to help, then I may just wait a year or so and buy a new head unit.
I wish there were a Pathfinder forum as active as this one, this forum alone makes me wish I had bought a Xterra instead of the Finder. Keep up the great work everyone!
#294513 - 07/06/02 11:20 AM
Loc: Vancouver, BC
Xterrian..... 5 Xterras for you man. Thanks for your replys and help. Hopefully I can work all this out.
#294517 - 07/06/02 10:39 PM
Loc: Vancouver, BC
Yeah that sucks. I wish it were the simpler DIN connector. And Xterran, I know it is a long haul building these things, I've been making these systems for cars for over 4 years now. Just that this is a new vehicle that I spent $42000 on and I don't really want to spend another $500 more to get a head unit with RCA AUX in. I have been running my current system for a couple years, but with crappy old FM Modulation, in both this Pathfinder and my last vehicle a Honda Civic SiR. The best system I have built to date, still has to be the first one I ever built. It was a DOS box, running a P120 CPU and would boot in like 6 seconds. Too bad it was controlled by a KeyPad and only played MP3s. My current system is a couple years old now, plays MP3s, DVDs, DivXs, games, etc..etc..etc.., but not nearly as nice as come of the new Mirco ATX board systems that are out there, like a friend of mine here in Vancouver has built. You can check his out at http://cobaltcarpc.com/ , we may be looking into producing these things....but would be a lot of work I think.
#294519 - 09/06/02 10:45 PM
Loc: Vancouver, BC
Yeah, I agree. Well the colbaltcarpc.com one right now has most of the stuff you mentioned (minus wireless networking) plus a lot more and it is projected to be around $400US. Now there are obvious options and stuff you can add on, but it is definately "doable"
#294520 - 12/06/02 05:04 PM
Loc: Vancouver, BC
Hey looking at the diagram for the "CN701 12 Pin Connector", the L & R inputs should be no problem, the grounds I take it can be left alone if my input device is already grounded, and there there is the "REQ-SIG In", "Rx-SIG In" and the "Tx-SIG Out"
Well the Rx and Tx are serial input and output connections, which I assume are to control the ch changer via the headunit controls, but what is the "REQ-SIG In" for? Is it for CD changer requesting input, or in other words this tells the headunit to switch the AUX on? If so, then maybe it will work the same way as the 8 pin DIN??
Any thoughts?
#294522 - 13/06/02 01:16 PM
Loc: Vancouver, BC
What? You don't like expensive bricks?? Hehehe
Anyways, thanks for your help. I'm going to see if I can get the schematics from Richard Krenn...then will let you know what they look like.
Thanks again!
#294523 - 14/06/02 06:54 AM
Loc: Mount Vernon, WA, USA
ElectroKen you have a PM
#294524 - 14/06/02 12:27 PM
Loc: Vancouver, BC
Sweet! Thanks a lot Richard!!!!!!
#294526 - 14/06/02 08:53 PM
Loc: Vancouver, BC
Hey EletroKen, that is OK. If we can get something working that would be sweet, but if we figure out that nothing can be done, that is OK as well. I would just hate to go out and buy something and find out I didn't need to, or connect something to it and then destroy it.
Thanks for all your help, both you and Richard have received 5 Xterras! Will be waiting for the results with great anticipation.
#294528 - 15/06/02 05:05 AM
Loc: Shelton, CT
#294529 - 17/06/02 06:59 PM
Loc: Vancouver, BC
How bout some friendly applause?? "Clap Clap Clap Clap Clap"
#294531 - 18/06/02 06:43 AM
Loc: South Carolina
ok.. i just found this thread and it has been making me giddy. i also want to play mp3s in my car. i have a simpler (though less comprehensive) system in mind. i have a portable cd player that plays mp3s. i have been thinking about how to get that stupid thing to play through my car stereo. now i may have it. but first... a few things....
1. i am sitting here at work and cant go out and check but does anyone know the manufacturer/model # for the 2002 stereo that came with the 6 disc changer (standard on se or an add on option)
2. has anyone tried something similar with this stereo?
3. xterrain.. that was a great detailed post on how to convert the headphones to connectors... i would rush right out and do it if it worked the same on mine.
thanks for any help... and will try to post back any info i get off the back of the stereo once i go look at it.
#294533 - 19/06/02 10:27 AM
Any thoughts on the Amp/Antenna out?
Richard
#294534 - 19/06/02 02:13 PM
Loc: Vancouver, BC
Thanks for your help Electroken. It is typical that something I desperately want, I can't have. Well, i guess I will have to start saving up for a new HU with AUX in.
Thanks for your help everyone, this is a great board!
