Yesterday at 10:44 AM
0 registered (), 239 Guests and 0 Spiders online.
#299112 - 27/06/02 06:49 PM Caps
mariner Offline
Loc: Vancouver
Does anyone have an opinion on capacitors. I am planning to add a amp to my system 400 watts I believe drawing 30 amps. I have read that the stock alternators are not so hot but upgrading to a better alternators is too costly for now. Should I consider an Optima Yello battery instead of a cap. I have set of IPF driving lights and do not plan to add any other electronics for now
#299113 - 27/06/02 07:04 PM Re: Caps
Ruttiger Offline
Loc: NJ
I've had a 400w amp in the truck for about 2 years now with no problems at all. I also run a 100w bazooka tube and 55w IPF fogs.
#299114 - 27/06/02 08:46 PM Re: Caps
traceyragsdale Offline
The normal rule is 1 farad for every 1000 watts, but adding a cap for 400 watts won't hurt. You could even get a 1/2 farad cap for cheaper and it would probably do the trick.
#299115 - 27/06/02 08:54 PM Re: Caps
Viper X Offline
Loc: Mercer Island, WA
I ran my 600 watt amp off an Optima yellow top and it was fine, even while running fog and driving lights. The alternator was still kickin in a little to frequently for me though, so I added a 1 farad cap just for shits and giggles. No noticeable difference, but the piece of mind is there and it will be easy to add an additional amp if I ever upgrade again.
My Xterra Pics
I wish I would have a real tragic love affair and get so bummed out that I'd just quit my job and become a bum for a few years, because I was thinking about doing that anyway.
#299116 - 27/06/02 08:57 PM Re: Caps
Viper X Offline
BTW, the yellow top kicks some serious butt. I run my stereo at full blast all the time while I'm playing bball or cleaning my carport or whatever and the battery has never died or failed to start, even after 4 hours of constant use. The biggest problem is my amp overheating after a while. Guess its time to add some fans.
My neighbor is runing a 15 farad cap off a stock battery and alternator and it only lasts a few minutes before the battery is dead.
My Xterra Pics
#299117 - 27/06/02 09:19 PM Re: Caps
spawn_x Offline
Loc: LA, CA
Don't need a cap for that little power... You'll be fine.
Raise up the music all the way (in an open area with no people around), turn on the lights, and see if your car "dims" when the base hits. I'm running about 700watts and mine gives me a SLIGHT SLIGHT dim SOMETIMES on hard tones - not a biggie, and is something I can live with so I'll pass on the cap. Now if you want it for the looks - that's different.
Keep your enemies close but your friends closer.
#299118 - 09/07/02 02:55 PM Re: Caps
GregD Offline
Loc: Londonderry, NH, US
I'm currently running a JBL 1200.1 powering 2 XTANT 10 inch subs and a US Acoustics 150X2 powering a set of CDT Audio 6.5 inch Comps up front off of the stock battery and alternator. The lights dim slightly but only on heavy bass notes with the volume cranked really high.
