0 registered (), 433 Guests and 2 Spiders online.
#299975 - 04/03/01 09:14 PM ElectroKen - need another source of power
InfX708 Offline
Loc: Ft. Bragg, NC
In one of your posts you told someone that if they needed another source of power to let you know. I'm wiring my CB up so that it will fit int he dash. It need a constant power suplly to maintain the memory. I was thinking about wiring it into the radio power wire. Think that would be bad?
'00 SE 4x4
300,000 miles, and counting
#299976 - 04/03/01 09:39 PM Re: ElectroKen - need another source of power
Sc00ter Offline
Loc: Austin, Texas(But retired Cali...
There are two power wires to your radio. A constant (duh) and switched. Meaning it is hot when the key is in any position but off. Be sure to wire into the constant power if you need the radio to maintain memory. Just be sure to turn the radio off when you get out!
The lighter outlet is alway's hot and should be a clean source of power too.
scoot
"If we weren't crazy,
we'd all go insane."
JB
Honey, did you move the car?
-- A typical morning at Candlewood suites.
#299977 - 05/03/01 04:30 AM Re: ElectroKen - need another source of power
ElectroKen Offline
Loc: Shelton, CT
I plagiarized myself from an earlier post:
A convenient place to get unswitched power on a 2000 X is at the power socket relay. This relay is light blue and can be found just above where the parking brake shaft enters the dash. Tap off of the red/white striped wire right at the relay socket. An insulation displacement connector like Radio Shack #64-3052 will work. That red/white wire is fused for 20 amps. The fuse is in the relay box just behind the battery.
#299978 - 05/03/01 06:33 PM Re: ElectroKen - need another source of power
InfX708 Offline
Loc: Ft. Bragg, NC
Is that the same relay that you yank to make the power socket always on?
'00 SE 4x4
#299979 - 05/03/01 06:38 PM Re: ElectroKen - need another source of power
ElectroKen Offline
Loc: Shelton, CT
Yup. That's the one.
