Problem posting?
11/06/24 10:33 AM
11/06/24 10:32 AM
0 registered (), 193 Guests and 1 Spider online.
#302213 - 20/09/04 02:04 PM cigarette lighter power accesory
Both my front and rear cigarette lighter power accessory for my 2001 EX stop working. The cigarette lighter fuze is not blow. Is there a separate fuze for the cigarette lighter power accessory? If so, which one? Is it combined? If the harness is burn out, how to fix it?
#302214 - 20/09/04 06:37 PM Re: cigarette lighter power accesory
did you check for power at the cig lighet itself?
a had a simular problem with mt 03. i was get power to the cig. lighter but it was the ground that was bad.
#302215 - 20/09/04 07:36 PM Re: cigarette lighter power accesory
There are two fuses, one under the dash for the upper lighter/outlet, the other under the hood for the rest of the outlets.
#302216 - 21/09/04 06:50 AM Re: cigarette lighter power accesory
Thank you GDCXC,2000 Denim Blue,XE 4x4 Auto your answer was accurate. I replaced the fuse in the Engine compartment and...is all good!
#302217 - 21/09/04 07:48 AM Re: cigarette lighter power accesory
No problem, that's your one freebie wink
Search here for "outlet fuse" and you'll discover numerous other posts where your question was asked and answered before.
