0 registered (), 104 Guests and 0 Spiders online.
#302511 - 16/07/04 09:43 AM Wiring fog lights
ok....i did do a search but never foun anything about this....
i have an 02 and its prewired for fog lights, but my problem is i really like the looks of the PIAA 510 lights, and they are only offered for the non-prewired X's. Is this a problem? can i still buy them? I also, dont want to wire them through a relay so they only come on when my headlights are on, i would like to be able to turn them off and on as i please. Any help, or pictures of your set-up or suggestions is greatly appreciated.
#302512 - 16/07/04 02:00 PM Re: Wiring fog lights
If you order the PIAA's, they will come with a switch and relay needed to wire them as you wish. I ordered the 525's and although they came with the switch, I bypassed it and wired them so they work with my low and hi beams.
There is no need to post a wiring diagram as your PIAA's will come with exactly what you are looking for.
#302513 - 16/07/04 03:04 PM Re: Wiring fog lights
If it is wired you can hook em up to the wiring. Clip the plug, connect black to black and the Black/Orange to what should be the white one.
Using that you can use the pre existing switch on the lever.
Check the AMPS, do not over load the fuses. I can not remember what the stock lights are in terms of amperage. And do not know what the 510 are for amperage.
#302514 - 16/07/04 04:22 PM Re: Wiring fog lights
Rickster43 Offline
Loc: San Antonio,Texas
My X came with no Pre-wired Harness for the Fogs...and added some PIAA 510's with the OEM Light Switch that Xterraparts.com has... Pic of the Light.... Pic of the Switch
Your Personal CADD Monkey...
#302515 - 20/07/04 11:47 AM Re: Wiring fog lights
do any of you have any suggestions on which PIAA's i should go with?
#302516 - 20/07/04 01:51 PM Re: Wiring fog lights
SMAN Offline
Loc: OREGON
I have a pre-wired Xterra, I'd like to buy oem foglights. Does anyone know if I can buy a switch and use the wires already there?? I'd like to be able to turn them on and off without the headlights. I know you can buy a replacement headlight switch, but tring to avoid that.... Thanks!
Never take life seriously. Nobody gets out alive, anyway.
#302517 - 20/07/04 03:52 PM Re: Wiring fog lights
Rickster43 Offline
I know there's a way to Re-wire your OEM Fogs, for individual use...some have done it here....but if not, you have to just buy a extra harness and Re-wire it and buy the switch from xterraparts.com...
#302518 - 20/07/04 04:39 PM Re: Wiring fog lights
SMAN Offline
Loc: OREGON
Hey Rickster43,
You understand what I am saying though right? I have seen that switch on xterraparts.com I want to use that switch with the pre-wired harness.
MrJonMan if you google for "Nissan Foglight Kit" there is a website that offers a different set of PIAA foglights that they recommend using if you're not going oem...
#302519 - 20/07/04 09:05 PM Re: Wiring fog lights
Rickster43 Offline
Hey Rickster43,
Well...like my first post up above...the post with the Pics...I had no Pre-wired Harness...and I bought the PIAA 510's and had somebody install the harness, lights and switch for me...there's an XOCer by the XOC name of ElectroKen...he know's how to Re-wire the OEM Pre-Harness....
