247
#302928 - 24/01/01 07:14 AM
Re: Anyone remember how to...
Loc: Sahuarita, AZ
Ken - I think I'll stop ar RS this afternoon and pick up a relay. One question tho, where is this relay located on the (00) X? dave and Xtoy - another project  ------------------
#302930 - 24/01/01 11:01 AM
Loc: Sahuarita, AZ
Thanks for the info Ken. This time of year, it's no fun spending time looking for a component that 'could' be located almost any place.
dave and Xtoy - lost and found
#302931 - 27/01/01 10:01 AM
Loc: Nacogdoches, TX
Do you know how to modify a 2001 Xterra SE as well? and after this modification will the fog lights stay on even when you turn the brights on? and one last question, will this mod void any warranties? ------------------ PoorBoy =-=-=-=-=-= 2001 SE 4x2 Alpine Green "Spooky" http://poorboy.virtualave.net/Xterra/spooky.html [This message has been edited by PoorBoy (edited January 27, 2001).]
Jonathan Former Owner of 2003 SE/SC 4x4
#302933 - 27/01/01 07:36 PM
Loc: Eddy, TX..
ElectroKen, Thanks for the help. I was looking for this mod too. This site sure is a God send to us newbies!
------------------ Roger 49/M/Texas Aztec Red 4X2 3pack Not really an "Old Fart"
"Caribbean Soul land locked in Texas"
#302934 - 31/01/01 07:25 AM
Loc: Sahuarita, AZ
Ken - Just wanted to let you know that the relay mod worked as advertised. I can turn on my OEM fog, now back-up lights at any time. Now all I need to do is wire in an indicator light so I won't forget to turn them off.
dave and Xtoy - did he say jumper cables?
#302936 - 01/03/01 04:15 PM
Loc: Sugar Land, TX
Hey ElectroKen, You wouldn't happen to have an extra modified relay on hand, would ya? I'll gladly reimburse you for it! ------------------ Paul Crescini '00 Super Black SE 4wd Auto http://www.lil-pino.com/xterra.html
#302938 - 02/03/01 11:26 AM
Loc: Sugar Land, TX
Thanks! I just emailed you my mailing address. ------------------ Paul Crescini '00 Super Black SE 4wd Auto http://www.lil-pino.com/xterra.html
#302939 - 03/03/01 03:41 AM
Loc: Eddy, TX..
Worked Great!!!
Many Thanks!
------------------ Roger SWXC member #37 TMTC member #951
#302940 - 03/03/01 09:18 AM
Loc: Arlington,TX USA
Run a jumper from the ac fuse to the coil energized post of the relay. your lights will be on whenever your X is on. I will post a pic as soon as I get down to the parking lot. Originally posted by PoorBoy: Do you know how to modify a 2001 Xterra SE as well? and after this modification will the fog lights stay on even when you turn the brights on? and one last question, will this mod void any warranties?
------------------ John O'Polka http://www.SWXC.org Member #28 Texas Motorized Trails Colition (TMTC) Member #940 2001 SE 4x4 Goldrush jgopolka@swbell.net http://www.geocities.com/opolka_2000/ http://albums.photopoint.com/j/AlbumList?u=1435837
John O'Polka His and Hers Mustang GT's Extreamly modified! Big cams and NOS
#302941 - 03/03/01 11:07 AM
I don't know how the switch works on the X, but on my car, the fogs work the same way: the low beam headlights must be on for the fogs to work. There was a wire coming from the hi/low beam switch that provides power to the fog light switch while the low beams are on.
All I did was cut this wire coming from the low beams, and replace it with a splice from a nearby ignition source wire, so my fog lights will work whenever the key is turned on and the fog light switch is on, but will turn off when I turn the car off. Foolproof. A wiring diagram helps.
#302945 - 10/03/01 07:47 PM
Loc: Sugar Land, TX
Hey Ken, I just received the relay today. Thanks!! I just have one question. I've located the fog relay that I am supposed to replace with the one you sent me. The problem is that I cannot figure out how to remove the relay. (please forgive my ignorance. i would normally try and figure it out by myself but it's late and it's cold) Is there some kind of tab that I have to depress to remove the relay? I tried to pull it out but I don't want to use too much force for fear of breaking something. I appreciate your help. I'll mail your money on Monday. ------------------ Paul Crescini '00 Super Black SE 4wd Auto http://www.lil-pino.com/xterra.html
