Problem posting?
Yesterday at 10:33 AM
Yesterday at 10:32 AM
0 registered (), 243 Guests and 2 Spiders online.
#303311 - 04/08/03 10:50 PM Yellow fog lights
Uzbad Offline
Loc: Durango, CO
I am thinking about adding fog lights to my X at the moment. From my childhood i remember that all fog lights used to be yellow and there was reason behind it, as it was not as reflective as white light that i keep seeing nowdays. Is there some reason why they all white now, or its yet another DMV regulation thing?
#303312 - 04/08/03 11:40 PM Re: Yellow fog lights
ChuckH Offline
The reason is that yellow lenses or bulbs reduce the light output, which was the way manufacturers used to solve the problem of light reflecting back to you before they discovered technology. With better reflector designs now manufacturers have been able to create better fog lighting with brighter light by keeping the upper cutoff of the beam pattern very crisp and by pushing the light out very close to the ground in front of the vehicle underneath the fog layer.
However, I feel both colors have their place. If you absolutely must mount your foglights above the bumper then you are probably better off using a yellow beam since it will be firing right into the fog and the lower light output will not reflect back as much. Also, I think yellow works better in rain than does yellow. If they are going below the bumper then get white light, IMO.
Anyway you look at it though, a proper beam pattern is what you are looking for more than color. For fog you absolutely cannot have light that strays upwards from the main beam pattern. You'd be amazed at how much different the main headlights can make too just by having some with a sharp cutoff at the top of the beam. Proper adjustment helps too.
#303313 - 05/08/03 12:31 AM Re: Yellow fog lights
#303314 - 05/08/03 07:34 AM Re: Yellow fog lights
Uzbad Offline
Loc: Durango, CO
Thank Ian and Chuck
that link explains why i dont see yellows here
"Under US Federal Motor Vehicle Safety Standard number 108 and Canadian Motor Vehicle Standards 108 and 108.1, headlamps as originally installed on motor vehicles (and as installed by anyone other than the vehicle owner) must produce white light"
and it also have same thing about yellows as i remember from my optics lessons.. Oh well. Just will have to comply with yet another odd regulation...
As of pattern, Chuck - yeah i understand that portion, but there is serious difference with color as well. Simplest example - check out how white light and how red light affects your vision at night. Wavelength is different - and imprint on the eye's bottom is different as well.
