122
#306348 - 26/07/03 06:40 AM
relocate Security LED light
I want to relocate my Security LED light so I can intsall a factory switch for my PIAA (back-up) lights. I am already using the other one for my front PIAA lights. So my questions are... Has anyone done this yet? Where should I move it to? Are there other alternatives to the LED light?  Any input is appreciated. and yes I did do a search but didn't find what I was looking for.
#306349 - 26/07/03 06:46 AM
Re: relocate Security LED light
Loc: ATX
I personally like the light on the drivers side door right next to the top lock... easily seen by someone "looking" in your truck... switch to a blue led, though... red would look tacky...
XOCEverything you need, if you don't mind the b.s.West Ham UFC -- Come On You Irons!!! www.myspace.com/kraigslist Kraig
#306350 - 26/07/03 08:15 AM
Loc: Mercer Island, WA
[img] http://im1.shutterfly.com/procserv/47b3dd11b3127cce9597d3b1dac70000001610[/img] Part of my Viper alarm system. Lights have 5 different patters and are noticeable from very far away. While I get asked all the time what they're for, I've never even had a false alarm (other than from something I knew about) in 2 years.
My Xterra Pics I wish I would have a real tragic love affair and get so bummed out that I'd just quit my job and become a bum for a few years, because I was thinking about doing that anyway.
#306351 - 26/07/03 09:29 AM
Thanks Viper-x but can I purchase those lights without a new system? I like your setup but Im not looking for a new security system. (yet)
#306353 - 26/07/03 03:06 PM
Loc: Covington, Louisiana
a red led came with my viper alarm and i installed it right next to my head unit, another popular first look for potental burglers.
Geaux Tigers!
#306354 - 26/07/03 04:35 PM
Loc: Mtl. Que. Canada
I've got mine of the top edge of the dash, centered above the 2 vents. Very easy visual from any direction (even from the rear)
#306355 - 27/07/03 05:31 AM
Thanks everybody and specifically ElecroKen I never thought of the different color bulbs having different voltage. Thanks for that little bit of info it may have saved me hours of troubleshooting.
#306356 - 27/07/03 08:53 AM
I've got a second red LED by the existing one that tells me the info about the alarm (blink X amount of times if the car was bumped, attempted to be started, etc) The Blue LED scanner on the dash can be added without an alarm, just a power, neg and remote turn on switch. Trick would be to figure out how to power it while the car is off, rather than on. There are many versions and colors of these, check out your alarm store or ebay for some ideas.
#306357 - 28/07/03 07:43 AM
Loc: Antioch, IL
I have done this inorder to create a free switch opening
"Reality is merely an illusion, albeit a very persistent one." Einstein
#678369 - 18/04/12 07:50 PM
[Re: Lockout]
Can in wire led strips in my car's SPAM
Edited by TJ (20/01/13 07:44 PM)
#678370 - 18/04/12 08:15 PM
[Re: Christoper]
Loc: Lansing, Michigan
It's hard to understand what you are really asking, but... I'll give you a shot at an answer. If I don't hit the mark, reply back with more info!
Can you wire this stuff the way you've described? Yes. Is it a good idea? Probably not.
It would be MUCH better to use the headlights (power going to them when turned on) as a trigger for a relay that then powers the LED lights/strips you want to add. That way, the only extra power draw you are putting on the headlight circuit is the relay (~1/10A). The power that goes to the LEDs comes from the battery, not the headlight circuit (and that fuse, possibly blowing it). You can then add your own switch to the new circuit so that you have the option of turning the LEDs on/off. That is, they won't ALWAYS be on when your headlights are on. Sure you could do this any way you wire it, but by using a relay, it is much safer, doesn't put any (realistic) draw on the circuit designed to power the headlights alone and you can control it at will, if you choose to wire it that way.
Hope this helps.
-G
'03SE
BFG AT/KO Custom fuse panels for electrical mods Custom backup solution mod (lights/camera/monitor) Custom switched power outlets (8+ total) Lots-o-Lights (6 driving lights, 10 total)
Original registration - Sep, '03 Pre-crash post count - ~1100
#678471 - 04/05/12 12:21 AM
[Re: Gonzo-2]
SPAM
#679906 - 18/03/13 02:31 AM
[Re: Allyson]
I must appreciate to all of you who participate this discussion about the security LED lights, but I am here to get some information about the car alarms, or other security system which could make my car secure.
Edited by michale (18/03/13 02:34 AM)
#680250 - 04/07/13 11:22 PM
[Re: Anonymous]
Thanks Viper-x but can I purchase those lights without a new system? I like your setup but Im not looking for a new security system. (yet) I think it depends on your security system that you have.Because some of the security system don't allow to connect that light with them.Just read the manual that help you to know that you can connect that lights or not?
