I work at a NAPA parts distribution warehouse so most of what I use comes from them.
I got a fuse block (balkamp part number 782-5316) it has a single post rated 80 amps that goes to 6 blade type connectors, each rated 20 amps with their own ATO fuse slots.
If I had a digital camera I'd give you a picture but...
My setup will be a 4 gauge wire running from postitve battery terminal, through a MIDI fuse holder (pn 782-1143) with an 80 amp fuse (pn 782-1145). Then through an ignition triggered 100 amp relay, then to the fuse box which will be located on the driver side firewall.
Unfortuneately I can't find the 100 amp relay anywhere so all the parts are in the garage waiting to be put on. All the wires are measured and the terminals are soldered on so as soon as I get a relay it will just be a matter of screwing things to the firewall.
I'll take pictures when I do it for future reference.
