#312027 - 17/12/01 02:10 PM Quick Connect
xterraintx Offline
Loc: Eddy, TX..
Hey guys and gals I need help with my light setup again. This time all I need a a quick connect idea for my light bar. I have it hard wired but would like to be able remove it too. A trailer connect will not hold the current. Pnut posted he found a 10 gauge one but I can't find one. I'm out of sources here.
Anyone have a suggestion beside each individual wire with a single connector. I have 4 lights on it.
Thanks...
#312028 - 17/12/01 03:12 PM Re: Quick Connect
Xrugger Offline
Loc: Chicago, IL
would something like these connectors work?
[Edit] I think you would have to weather prof these some how.
[ 12-18-2001: Message edited by: Xrugger ]
Joe
#312029 - 18/12/01 06:36 AM Re: Quick Connect
BennyLen Offline
Loc: Huntsville, AL
I have 2 155 Watt KC daylighters up top. I used a 4 wire trailer wiring harness but I split the current between two wires each (+ & -). That way instead of about 25 Amps through a 18G wire I get about 12 Amps through it and the 18G works fine. Since you have 4 lights, a single harness may still not be enough. You might consider using 2 harnesses. Maybe one for the Positive side and one for the negative side.
The harnesses mentioned above look impressive but I don't know how well they will hold up outside, on the roof. For the ones like Pnut used try checking at an alternator supply house. That's the route I would have tried, but I already had my setup when I thought about that.
Benny
Benny\'s Xterra site
#312030 - 18/12/01 07:50 AM Re: Quick Connect
xterraintx Offline
Loc: Eddy, TX..
Xrugger, thanks for the post. I did not find a connector I wanted but the protective boot is something I have been looking for. I have a removable receiver winch and the connector sits open when not in use.
BennyLen, the alternator shop Idea is great I will check after work.
Thanks...
[ 12-18-2001: Message edited by: xterraintx ]
#312031 - 18/12/01 09:15 AM Re: Quick Connect
sgary Offline
Loc: San Juan Bautista, CA, USA
Try a hobby store, they should have good quality plugs that will handle 30-40 amps continuous for R/C car batteries. Make sure you get the good quality kind for racing, they are usually made out of silver or gold. I've been out of the R/C stuff for a while so I can't remember the who makes them but if you go to a good hobby store they should be able to find what you are looking for.
Gary T.
2001 Silver Ice
4x4 SE Auto
#312032 - 18/12/01 10:21 AM Re: Quick Connect
ChuckH Offline
Hahahaha, yeah if he's running 4 guage power leads to his lights! Mmmmmm, holy crap!
#312033 - 19/12/01 07:31 AM Re: Quick Connect
xterraintx Offline
Loc: Eddy, TX..
SGary, you did it. I stopped by the local hobby shop last night and those battery connectors were exectly what I was looking for. I bought an extra pair just in case.
THANKS Again and I recommend these for this or any other application.
