Problem posting?
11/06/24 10:33 AM
11/06/24 10:32 AM
0 registered (), 217 Guests and 0 Spiders online.
#321893 - 22/09/05 12:29 PM Hey Ty or anyone else with a Shackle/AAL lift
Upon doing the Poor Man Lift, I noticed that my alignments was never right, even after taking it to the dealers. So I took it to Firestone (Monday) and they to explained there was a problem, Caster was impossible to set to factory spec and camber was an issue too. Well I got the opporunity to go into the bay with the tech and we worked on my alignment. I already was understanding that Caster numbers could be all over the place and it is important for tire wear that Camber be 0 so we set my truck to have camber of 0 on both sides, and caster to be higher on the passenger side like +.2 - +.5 degrees over the drivers side, the actual number of degrees itself will vary. The higher caster on the passenger side corrects the right side "drift/pull" that Xterras always have. And the zero cambers can help for even tire wear. Toe should be set to factory specs without a problem. So far my results are great. The truck drives straight as an arrow no pull/drift at all. Just thought I would share.
#321894 - 22/09/05 12:34 PM Re: Hey Ty or anyone else with a Shackle/AAL lift
Thanks for the info Gabe. Which Firestone did you go to and who did you work with, so I can schedule an appointment with them.
#321895 - 22/09/05 12:37 PM Re: Hey Ty or anyone else with a Shackle/AAL lift
Firestone MasterCare Service Centers Surprise
11541 W Bell Rd
Surprise, AZ 85374 - 9403
(623) 974-6676
John was the name of the Tech.
#321896 - 22/09/05 02:49 PM Re: Hey Ty or anyone else with a Shackle/AAL lift
I have a right drift on mine. A friend I graduated with gave me the same deal, It's just the result of stock UCA's being intentionally set out of spec (the t-bar crank). It's not bad, but it's noticeable.
#321897 - 22/09/05 03:26 PM Re: Hey Ty or anyone else with a Shackle/AAL lift
Dude, why do you not go to 35th ave and Bethany where we have friends? [Freak]
#321898 - 22/09/05 05:17 PM Re: Hey Ty or anyone else with a Shackle/AAL lift
I got mine 1/2 off at the one on Bell :p
#321899 - 27/06/06 11:28 AM Re: Hey Ty or anyone else with a Shackle/AAL lift
Any good AZXC friendly shops around Tempe for alignment (discount wink ?)? Also, do I just need to get the front wheels done or all four after a PML?
#321900 - 27/06/06 12:56 PM Re: Hey Ty or anyone else with a Shackle/AAL lift
I heard over on N4W that Turners in Tempe or mesa is a good place for lifted nissans.
#321901 - 28/06/06 04:05 PM Re: Hey Ty or anyone else with a Shackle/AAL lift
Not Turners....It's Shumans, and it's on Siesta just south of Rio Salado (2 blocks west of 101 freeway). Call for an appointment at 480 894 2165...last I knew, they still charged only $40
