0 registered (), 56 Guests and 0 Spiders online.
#35997 - 05/10/07 11:24 PM Power steering problems....
I think my power steering is going out... I can't turn the wheels if I'm not moving?! What's that going to cost me? Every time I get close to my gear reduction, something else goes wrong! I'm starting to get a bit frustrated mad
Shawn
#35998 - 06/10/07 05:53 AM Re: Power steering problems....
Have you checked the fluids and stuff before you get frustrated?
#35999 - 06/10/07 07:23 AM Re: Power steering problems....
Also did you change Tires or Wheels lately?
#36000 - 06/10/07 07:32 AM Re: Power steering problems....
Fluid is fine. I had the system flushed about 6 months ago. I put new belts on a few weeks ago and they are tight and not slipping. The pump turns freely with the belt off. Tires have been on for about 6 months as well.
Shawn
#36001 - 07/10/07 08:42 PM Re: Power steering problems....
How do I know if it's a pump problem or a steering box problem? It has to be one of those two I would guess...
Any other ideas.
Thanks,
Shawn
#36002 - 07/10/07 08:50 PM Re: Power steering problems....
When you try to turn the wheel does the pump lock up or turn fine?
I'm having a similar issue with mine now as well. First time replaced the pump and now it's intermittent. Sometimes works fine, sometimes I can only turn when moving.
Power steering pump issue on mine.
