Yesterday at 10:44 AM
0 registered (), 239 Guests and 0 Spiders online.
Page 2 of 2 < 1 2
#392246 - 23/04/06 06:42 PM Re: Shrockworks Roof Rack!
OK Id be in on a roofrack. Id perfer that over the rear bumper for the spare. It would nead to meet the following criteria:
*NO TALLER THAN STOCK
*4 light mounts on the front 1-2 in back
*Holes to pass the Lights' wiring inside the framework.
*Uses the entire length of the roof
*Avalible flat panelling so things dont drop through
*Takes styling cues from landrover Discoveries (they have some sweet roof racks)
*optional locking tire mount
*CB arial spot????
*Silver Color match
Ive got big plans this summer and A rack that I could load a Hi lift, spare, Storm case, and lights would be great. Then when I got home unload it and still get into the garage.
#392247 - 09/05/06 04:54 PM Re: Shrockworks Roof Rack!
Shrock Offline
Loc: Houston, TX
OK, well you guys have methinking about it. Keep the feedback coming.
Jim
Jim Shrake
www.ShrockWorks.com
#392248 - 10/05/06 01:02 AM Re: Shrockworks Roof Rack!
some place to mount an AUX brake light since people this far into the game will also have your tire carrier, some places they won't be able to pass safety because of the covered brake light..
Maybe some way to put tabs or removable pipes in so you can extend a tarp or covering off the side to provide shade if the truck is being used in a camping setting.
I would also try and see if you can use the same size piping or something comparable to Yakima so those that have all those little gadgets from Yakima won't be out if they get your rack.
Shrockworks airdam
maybe some sort of a track system to put in dividers. its kind of nice to be able to put dirty yank cables in my front basket while I have clean tents in my load warrior.. the two never meet each other which is a good thing..
Don't go light on the number of tie down options..
maybe a covered area that is lockable.. I like the setup on the 05 & 06s That way you can put your stinky boots outside after a hike and not worry about them getting wet/stolen..
Sorry they are unorganized but I was brainstoriming.. OBTW expect a call from me I need a front skid plate for an ARB..
#392249 - 12/05/06 05:32 AM Re: Shrockworks Roof Rack!
*CB arial spot????
*Silver Color match
I like these ideas with the exception of the entire roof line. I've found the cargo box extremely useful and I'm not the least bit interested in giving that up. Sorry, it's a keeper.
Big things for me:
1. Mounts for lights front and rear
2. Mount for CB antenna
3. Low profile design
4. Place to put Shrockworks sticker...hee hee
#392250 - 12/05/06 07:38 AM Re: Shrockworks Roof Rack!
The problem is that to make an aftermarket rack and keep the stock roof bin would be a real pain and it would look silly. If that is your goal, just use a Loadwarrior. Here is my suggestion.
First off, one that fits the 05-06 X.
I would want something similar to the Calmini rack w/:
*Removable expanded metal floor.
*The bottom of the rack should follow the roof line, but the top should stay the same height. (so the front is deeper than the back)
*Front and rear light tabs
*Front Air Dam
*Some sort of release system so the rack can be removed without needing to unbolt it from the roof (the mounts can stay).
*Compatible with the Yakima Loadwarrior accessories.
*Front should be formed to fit some sort of aftermarket case (ie. Pelican case) so those of us who the stock front bin and don’t want to lose that functionality.
#392251 - 13/05/06 02:38 PM Re: Shrockworks Roof Rack!
Yes! Yes! Yes!
I am first in line!
I want the ability to have a cooler over the front, light tabs in the front/rear, and a way to support/strap Sceptor gas/water cans!
This way I can spend a little more money with you!
By the way, the wife needs you to fill out the tax forms so I can claim you as a dependent... [Spit]
#392252 - 13/05/06 03:01 PM Re: Shrockworks Roof Rack!
All great ideas. I would still like it to be made out of aluminum.
I'm getting tired of painting.
#392253 - 13/05/06 03:41 PM Re: Shrockworks Roof Rack!
SAY IT ISN'T SO!!! [Too much XOC]
#392254 - 13/05/06 04:04 PM Re: Shrockworks Roof Rack!
Your paint shop run out of blue and yellow?
Page 2 of 2 < 1 2
