ECXC 2026!
04/04/26 10:24 AM
0 registered (), 61 Guests and 0 Spiders online.
Page 2 of 3 < 1 2 3 >
#393792 - 04/02/05 10:36 AM Re: 2005 CALMINI Xterra
CALMINI Products Inc. Offline
Loc: Bakersfield, Ca.
Patrick, the kit will be available in two basic forms; one that utilizes the factory coil over shock and the upgraded kit that will include our very own CALMINI Coil-Over shock setup. More details to follow regarding this as parts are in the works. We have our coil-over design in testing and hope to have pictures and specifications in the near future. Cary, that is indeed an internal rack that allows for a little more cargo organization than just the floorboard. More than likely it won't be a production part unless we see interest. Keep the questions coming...
Sales Department
Steve Kramer- CALMINI Products Inc.
#393793 - 04/02/05 10:39 AM Re: 2005 CALMINI Xterra
So are you (Calmini) going to start offering the built up version of the Xterra, sort of like AEV does to the Jeep product (American Expedition Vehicles) or am I just reading too far into this?
I only ask because you mentioned that the paint scheme is the only choice, in an earlier post.
#393794 - 04/02/05 10:43 AM Re: 2005 CALMINI Xterra
That rear tire carrier might find a few buyers just because it hides the haphazard-looking arrangement of the rear hatch bulge, handle, and badging wink
Any hurdles to deal with to make the new rack-and-pinion steering work with the lift?
#393795 - 04/02/05 10:45 AM Re: 2005 CALMINI Xterra
socalpunx Offline
Steve, this new platform with the benefit of C/O's must be like manna from heaven for you guys after having to make due with a t-bar set up with limited options.
#393796 - 04/02/05 10:49 AM Re: 2005 CALMINI Xterra
I mentioned the paint scheme as it was brought up in an earlier post mentioning the possibility of removing the graphics if they were decals. This is a project vehicle for Nissan USA. There were no issues with the rack and pinion steering setup and yes, we are excitied that Nissan is using a chassis design that lends itself to much more modification than the previous setup.
Sales Department
#393797 - 04/02/05 10:50 AM Re: 2005 CALMINI Xterra
LAXterra Offline
Loc: West Los Angeles, CA
I really like the idea! [ThumbsUp]
Back in 2000 or 2001 some company gave SCCX a cheesy, flimsy rack that strapped down to the tie down hooks. It had hardly any room underneath and I was afraid to put anything even semi-heavy on it. frown
With the 2005 internal slide rail... CALMINI's looks like a solid AND quickly removable at base camp rack... so we could sleep in the back. If I had a 2005... I would definitely get that rack! [ThumbsUp]
#393798 - 04/02/05 11:14 AM Re: 2005 CALMINI Xterra
hattrik21 Offline
Loc: Lewisville, Texas
The final slider design is still in the works but welding will more than likely be recommended for reinforcement. They do mount directly to the frame and the early model year units will not be adaptable.
Sales Department
If we welded the previous make of the sliders, would that not work? Is there a distance differance from the frame to the body or is it a length issue?
SWXC Member # 65
TMTC Member # 1795
www.Texas-X.net
www.TheNewX.org
#393799 - 04/02/05 12:03 PM Re: 2005 CALMINI Xterra
fastdrmr Offline
Loc: SLC, UT
Along those lines with the sliders, it is apparent that the wheel wells flare down toward the sliders. In your first pix, the sliders look shortened by a bit. Is this true or just a shadow effect? Perhaps the previous sliders are too long because of that flare?
I really like the effort and design put into the entire set-up. I love the approach/departure angles! The interior rack is interesting from the perspective that you could sleep (legs) under it and keep your gear on the shelf. I like it too!
On the rear tire carrier, any thoughts on integrating a hi-lift attachment spot? Jerry cans?
Great work!!! [ThumbsUp]
KE7AEY
#393800 - 04/02/05 12:20 PM Re: 2005 CALMINI Xterra
tcdesign Offline
Loc: Hudson, WI
It was a bitch getting those graphics off.
Perspective on the wheels/tires is a little off, but...
How many of you believe in psycho-kinesis?
Raise my hand...
#393801 - 04/02/05 02:17 PM Re: 2005 CALMINI Xterra
Like I said before great job on the lift. I'm impressed with the whole 5" of lift. Do you guys think that you can go higher then that or is that the limit?? Are you guys looking at the possibility of a body lift at all?? 3" of BL would be kick ass for a total of 8" and that could possibly clear some bigger tires. laugh
#393802 - 04/02/05 04:52 PM Re: 2005 CALMINI Xterra
The original sliders were notched and angled opposite each other whereas the new style is a straight through type of bracket.
Robert, regarding the skids, they are the same ones in all of the pictures, it is simply the shadows changing the look as you predicted. They have a slightly different angle on the edges than the previous year X so it appears as though they are not quite as long.
The Hi-Lift and Jerry Can mount would easily be something we can add to this setup and possibly even the earlier year models as well. We are here to build the parts that you want. If you want it, tell us. [ThumbsUp]
Regarding the height, 5" is it. Any more lift and you are looking at some heavy modification. We are entertaining the idea of a body lift. It will largely be based on whether we see enough interest. Keep them coming...
CALMINI Product Inc.
Sales Department
#393803 - 04/02/05 06:20 PM Re: 2005 CALMINI Xterra
01SalsaXterra Offline
Loc: Suffolk County,NY,USA
Great looking lift on the 05. Did you guys need to trim anything to fit the 33" tires? And is it possible to fit larger tires with some trimming (plastic and sheet metal)?
I got "IT" from ebay.
Now it burns when I pee..
#393804 - 05/02/05 12:23 PM Re: 2005 CALMINI Xterra
I would be real interested in the tire carrier if had more carrying capacity. There is going to come a time that I will be in the market for one and I would really like to have the option to purchase a Calmini set up rather then be limited by other manufactures. The other option is not a bad one however.
Haveing options is good.
#393805 - 05/02/05 01:40 PM Re: 2005 CALMINI Xterra
ButterBean Offline
Loc: Walla Walla
Looks good
#393806 - 05/02/05 10:14 PM Re: 2005 CALMINI Xterra
...Alan, the Frontier kits are also in the works and we are also finishing up this same system on the 2005 Pathfinder...
Steve, if it wouldn't be called [Rainbow] , I'd kiss you on the lips!
As it is, I'll just shake your hand at goneMOAB. wink
Still saving for the SAS kit as well.
Would you be interested in a contract for my first born? Would make things a bit easier for me. laugh
#393807 - 08/02/05 10:43 AM Re: 2005 CALMINI Xterra
Very nice looking setup. Just wondering - does installing the front bumper have any effect on proper deployment of the airbags? My X will be a daily driver so I don't want to adversely effect it's safety. Thanks.
#393808 - 08/02/05 11:21 AM Re: 2005 CALMINI Xterra
Damn that thing looks HOT!!!! The curves, the smooth lines.
When are you expecting the procuction lift kits for the 05s? Besides soon.
What are you doing in the rear for the lift? Is it the same as the 00-04 version?
#393809 - 14/02/05 07:12 PM Re: 2005 CALMINI Xterra
Wow....with that kind of transformation, that is a sharp looking truck! Got me thinking of possibly trading the '03 for an '05... cool
#393810 - 15/02/05 12:10 AM Re: 2005 CALMINI Xterra
I'd trade my sister for a truck like that. 'Course, I don't have a sister; but if I did...
#393811 - 15/02/05 06:57 AM Re: 2005 CALMINI Xterra
Nice work!!!
Now lets see it with some mudders on it!!
#393812 - 15/02/05 07:40 AM Re: 2005 CALMINI Xterra
I hate the front end. :puke:
#393813 - 15/02/05 11:33 AM Re: 2005 CALMINI Xterra
tha thing looks ugly. I hope they come out with an 04' face kit for the new 05s
#393814 - 15/02/05 01:06 PM Re: 2005 CALMINI Xterra
hattrik21 Offline
WHY? If you like the look of the 04, buy an 04. I really don't see what theres not to like about them.
SWXC Member # 65
TMTC Member # 1795
www.Texas-X.net
www.TheNewX.org
#393815 - 15/02/05 02:08 PM Re: 2005 CALMINI Xterra
Not bad at all!!! I must admit that I didn't really like the 05 look, but now I love it (modified look, that is)!
I must agree that 5 inches of suspension lift plus another 2 or 3 inches of body lift woul kick ass.
Steve, you mentioned that anything above 5 inches would require heavy mods. Out of curiousity, what 'heavy mods' are we talking about, specifically?
#393816 - 15/02/05 08:43 PM Re: 2005 CALMINI Xterra
blizzard Offline
Loc: Yarnell, AZ.
What kind of wheels are those??I'd consider them if they weren't so shiny. Do they come painted?
I've been trying to find something I like, not as much out there as I would think. Someone needs to make a Minilite/Panasport type of wheel that will fit.
"What's the point in going out? We're just going to end up back here anyway" H. Simpson
