0 registered (), 69 Guests and 0 Spiders online.
#397456 - 02/06/05 08:55 AM Question
Hey yall! This year will be my first year going to ECXC. I'm looking forward to it and meeting everyone! I have a question though. I'm probably going to buy the rear shackles to lift my truck a little bit, but i dont' even want to attempt doing it, i'll break something. so do people mod at ECXC? or is a PML too difficult?
#397457 - 02/06/05 09:20 AM Re: Question
Its not that hard....but, it eats into other's wheeling/party time...so, if you are going to do it there, coordinate who's helping, and when/where....like after wheeling the first night...or, if you are getting there early...doing it Thursday afternoon/evening....etc.
You can really speed things up by doing some prep work....like getting some nut blaster/penetrating oil...and spraying the shackle attachment points (top/bottoms), and the T-bar adjuster nuts and bolts - NOW! (The more lead time you give it, the easier it will come off when you get there...and the less time it will take. Most of the time consumed is breaking free rusted parts...so, the penetrating oil thing is a big plus (Mandatory).
W/o rust problems...it takes less than 30 minutes to crank the front, and another 30 minutes to change out the shackles...not too bad.
(If you haven't yet)...take off the aluminum step rails and mud flaps...they tend to get wrecked off road...and this way they stay nice so you can sell on e-bay, etc...to get some steel sliders, etc.
#397458 - 02/06/05 09:58 AM Re: Question
swampwrecker Offline
Loc: Brunswick, GA
It's not a problem to do the install at ECXC. There are plenty of people there that can give a hand. There will even be a Master Nissan Technician there as well.
Have you already cranked the torsion bars? If you haven't, the rear is going to be seriously higher than the front. I wouldn't recommend cranking the t-bars at the campground because you will need an alignment if you crank the t-bars enough to level out the truck with the shackles. If the wheels are out of alignment enough, you can really put a lot of extra wear on the front tires.
I would just post your intentions to do the install at the campground over on the ecxc.com message board. There are a lot of folks there that don't read XOC. Giving them a heads up will make it easier to get help once we're all there. I don't think a year has gone by that someone hasn't done some serious work on their truck at the campground.
-Michael
Michael Girardo
East Coast Xterra Challenge
swampwrecker@ecxc.com
#397459 - 02/06/05 12:34 PM Re: Question
You can most likley fudge the alignment well enough to get through the weekend (eyeball it), as you are really just getting the camber back....and do a real one the following Monday at an actual shop, etc.
#397460 - 02/06/05 12:57 PM Re: Question
check your PM's..
when i did mine last week, it needed an alignment right away.. i wouldn't try offroading without an alignment after the lift. like the pm says, i'll help if you want smile
~Sarah
Moderator:  swampwrecker
