Yesterday at 10:44 AM
0 registered (), 302 Guests and 0 Spiders online.
#399017 - 20/03/02 12:48 AM goneMOAB Site Updated
The itinerary page has been updated with an event map, radio frequencies and contact information.
#399018 - 20/03/02 12:06 PM Re: goneMOAB Site Updated
OK, I'll bite. Why different frequencies/channels from one day to the next?
#399019 - 20/03/02 01:10 PM Re: goneMOAB Site Updated
Because all the other frequencies are being used by EJS participants.
#399020 - 22/03/02 05:58 PM Re: goneMOAB Site Updated
oleblue Offline
Loc: Winter Park, CO
I have a question now about the FRS Radio codes and sub codes. I have a Real early FRS and it is CTCSS not DCS and is an off brand so not sure if it is using the same frequencies. (There is no standard in the industry) Mine is Channel 10 467.6125 MHz and for code (sub channel) 1= 67.0Hz, code 4 = 74.4Hz and code 5= 77.6Hz.
Is this compatible with the ones listed that you talk about or would mine have to be some other code
-Thread Killer.
#399021 - 22/03/02 06:08 PM Re: goneMOAB Site Updated
It's probably not compatible.
#399022 - 22/03/02 06:29 PM Re: goneMOAB Site Updated
oleblue Offline
One way it has to be because all FRS's use the same MHz freq, may just not be labeled the same. My channel 10 might be most others channel 1, just need to know the Frequencies so can match up. only problem might be when you say sub channel are you talking radios that use Digital Coded Squelch (DCS) or ones that uses Continuous Tone Coded Squelch System (CTCSS) DCS and CTCSS are not compatable.
-Thread Killer.
#399023 - 22/03/02 07:14 PM Re: goneMOAB Site Updated
LAXterra Offline
Loc: West Los Angeles, CA
FRS Channel 10=467.6125 MHz
Subcodes:
01=67.0 Hz Freq
04=77.0 Hz Freq
05=79.7 Hz Freq
#399024 - 22/03/02 07:24 PM Re: goneMOAB Site Updated
oleblue Offline
Subcodes:
01=67.0 Hz Freq
04=77.0 Hz Freq
05=79.7 Hz Freq
Okay, thanks, this is how mine is, I just need to use subcodes 5, 6. mine is:
Channel 10= 467.6125 MHz
Subcodes:
01=67.0 Hz
04=74.4 Hz
05=77.6 Hz
06=79.7 Hz.
Just minor adjustments, thanks.
-Thread Killer.
