0 registered (), 116 Guests and 0 Spiders online.
#405854 - 27/06/04 08:38 PM Increasing HorsePOWER, Help...
Hello, I have a 2000 XE Nissan Xterra V6. And Iam trying to squeeze out every litte pony out of it. My modifications to the truck so far has been: an Alpine supercharger, custom fiberglass hood scoop, Iridium spark plugs, Nology Hot Wires, K&N FIPK Gen II Intake, Optima Red Top Battery, and a Flowmaster 50 (2.5'') dual exhaust. I was thinking of getting the SLR headers, but living in CA, they wouldn't pass the smog test (since they take out the cats). So if anyone knows of any other place I can get a custom set of headers without taking out the cats, please help. I was also looking into getting a UNICHIP or CAMS... any suggestions or comments would be greatly appreciated.
#405855 - 28/06/04 03:30 PM Re: Increasing HorsePOWER, Help...
Have you looked into the ignition system from MDS?
#405856 - 28/06/04 03:35 PM Re: Increasing HorsePOWER, Help...
Strom Offline
Loc: Los Angeles, CA
Has the Alpine Developments supercharger passed CARB regulations? It still says "Pending" at http://www.tonemonday.com/
#405857 - 13/07/04 04:12 PM Re: Increasing HorsePOWER, Help...
you got a lot of mods there and i am new to the xterra but if it is like any other engine these things will help. Since you have forced induction you should look to porting some items. Throttle body, intake manifold runners, and take the head off and send it out a machine shop and improve the airflow. I come from hondas where this is a step that can get pretty decent gains from a motor. If you can find someone to cut you some cams with a more aggressive profile but you don't want much since you have F/I. Check a crower cams they may be able to help you. Also depending on budget someone can make you a set of headers so they don't involve removing cats (damn expensive though) I am pretty sure S/C engine prefer short runners and long downpipe if you go for it. Chips aren't the best product since they aren't programmed to your specfic engine and mods unless you are able to have them programmed but that deals with dyno tuning. Fuel is another thing to look at. Upgrade injectors RC injectors can balance and blueprint yours i am pretty sure and if you can get a fuel pressure regulator and modifiy it to fit the X that would help but again when you really start to get serious into horsepower you have to get on a dyno and start messing with fuel, ignition and timing to find the best power b/c if you don't you could be actually losing power. Good Luck in you adventures to find more power. Hey if a 1.8L Honda motor can put out 500+ hp the X's 3.3L has power you just have to find it. I am sure the block of 3.3 can handle a ton of power, Nissan makes strong motors. Hope this helped you out!
#405858 - 13/07/04 05:48 PM Re: Increasing HorsePOWER, Help...
BradLee Offline
Loc: Black Hills
How much increase do u have in horsepower with what you have right now?
The search function is "BROKEN". Wish I could put jumper cables to this ol' XOC.
#405859 - 13/07/04 08:47 PM Re: Increasing HorsePOWER, Help...
I don't see anything mentioned about the fuel management. Probably had something added to boost the fuel pressure, but what about the mixture itself?
I'd suggest something on the order of fuel management, similar to a stand alone system, or at the very least, an Air/Fuel Controller, such as an A'PEXi unit. Their SAFC-II is in my car, and even with just a Cold Air Intake, I noticed the difference. Just need a dyno tune to be precise. But with all your improvements, that would seem like fun anyway!
