Problem posting?
11/06/24 10:33 AM
11/06/24 10:32 AM
0 registered (), 104 Guests and 1 Spider online.
#406503 - 19/02/06 12:37 PM 2000 xterra dies after running??
IT starts but dies after 10 to 20 minutes.Then i can restart it again. It all started when it just died on the highway.I tried heat in gas tank ..Thoght it might be bad gas. have any ideas?
#406504 - 19/02/06 12:41 PM Re: 2000 xterra dies after running??
have you checked your fuel filter?
#406505 - 19/02/06 12:43 PM Re: 2000 xterra dies after running??
Do you think it could get cloged after running for 15 minutes
#406506 - 19/02/06 01:24 PM Re: 2000 xterra dies after running??
It may be abvious, but was your truck recalled for the fuel sending unit recall? It may bo corroded as per the recall and shorting out/ stops working after some time.
No check engine light? No sputtering?
Is the fuel pump working ok? You can hear if it's running when you put the key in ignition, turn it to 'on' but not start it. There should be a buzzing/humming noise from the back, that's the sound of the pump turning on.
#406507 - 19/02/06 01:34 PM Re: 2000 xterra dies after running??
I get a sevice engine soon light...
when it wont stat i dont hear no humm of the pump...It may be the recall like you say...i will see what it sounds like when it does start..No sputtering when it does start ...it sounds normal
#406508 - 19/02/06 01:41 PM Re: 2000 xterra dies after running??
Run it over to Auto Zone if you have one nearby. They will scan the codes for free and tell you what they are. It'll give you more ideas.
#406509 - 19/02/06 01:43 PM Re: 2000 xterra dies after running??
Also call you dealer and have them run your VIN number. If you're not the first owner, you don't know what recalls were done to her. By giving them your VIN they will tell you whether this or any recalls have been done before.
If the fuel sending unit has not been done before, it may be it, there's a good chance.
#406510 - 19/02/06 01:48 PM Re: 2000 xterra dies after running??
Thanks for your responces..i will get to it monday if the dealer is open.I do have a extended warranty so it should be all good.72 months 70000 miles.I must say this is teh first problem i have had with my XTERRA.The only problem is i am on a moutain lol so i will have to have it towed.The nearest dealer is 30 miles away.
Thanks again at least i have some ideas whats wrong...
#406511 - 19/02/06 03:10 PM Re: 2000 xterra dies after running??
Keep us posted on the outcome. It would be useful for futire reference.
#406512 - 19/02/06 03:28 PM Re: 2000 xterra dies after running??
If you want to, pm me your VIN # now, and I can check on it. You don't have to wait until Monday. I have national access to certain portions of the Nissan DCS. wink
#406513 - 20/02/06 07:11 AM Re: 2000 xterra dies after running??
Yes, you do have an open R0402 NoSalt Campaign open on your vehicle. If it's dying, then Nissan should be picking up the tow bill to the nearest dealership. Mind you, the nearest dealer, not the one you may prefer!
Your vehicle was originally purchased at Shingle Springs Nissan, in Shingle Springs, Cali. on 8/18/2000.
Glad to help!
#406514 - 20/02/06 06:46 PM Re: 2000 xterra dies after running??
I had my Xterra towed to the dealer in carson NV.I called the dealer first.I told them about the recall and the sending unit.The service manager said no way it wasn't that.Well he called me later today and said thats what it was...lol.i asked him about the other recalls and he said that the one with the alloy wheels wasnt mine .I am checking on that now.
I just want to say thank you so much for your help ...responces..I am totally wowed
Semoer fi
chcuck
#406515 - 20/02/06 07:08 PM Re: 2000 xterra dies after running??
You only had the one recall that pertained to your particular truck. The other recall would be excluded by VIN.
Glad to hear that it all worked out.
#406516 - 20/02/06 10:11 PM Re: 2000 xterra dies after running??
Semoer fi
chcuck
Glad to hear that you got it worked out!
