#409295 - 22/03/05 01:01 PM adding torque to a 4cyl X
i'm looking to beef up my X in the next year...i recently got the tires and rims out of the way and i'm confused...is there a way to get enough torque out of the 4banger to seriously wheel her or am i pretty much spinning my wheels?(pun totally intended) [Finger]
anyway, if you have done anything to a 4cyl or know of anyone that does, feel free to post as i'm now doubting that it can be done....
#409296 - 22/03/05 01:05 PM Re: adding torque to a 4cyl X
Carlton McMillan Offline
Loc: MN
Seeing as you only have 2wd there is not much hard core stuff you will be doing in your Xterra. Especially since you do not have a low range transfer case that you can change the gearing on.
Putting larger tires on there is going to stress your clutch a bit.
#409297 - 22/03/05 01:52 PM Re: adding torque to a 4cyl X
I didn't know they make 2.4l SE's..
IF you go to larger tires, regear the diff, and consider a locker at the same time. Thats about the best you can do after intake & exhaust. might look at 240z parts, as the engine is similar.
#409298 - 22/03/05 01:55 PM Re: adding torque to a 4cyl X
so, am i reading that i should get over it?....there is not many ways to add torque to my 4banger and i should not try to wheel her too hard and perhaps look at a different rig?
#409299 - 22/03/05 02:16 PM Re: adding torque to a 4cyl X
They don't. He has an XE or a V6.
Surf2snow - you can't "seriously wheel" a 2wd SUV.
