I started posting this as a reply to an old R&P thread in Drivetrain - but really the issue is beyond that - so here goes:
I can't maintain freway speed (70-75mph) without my auto tranny constantly downshifting and unlocking the torque converter with these heavy 32" tires on steelies. I tried with the stock wheels/tires and it's really not a whole lot better. This truck is just a MAJOR dog and it's starting to get to me.
I pretty much have to leave the overdrive off and run at 4000rpm all the time on the freeway to be able to maintain speed up and down hills - which I don't like (I drove all the way back from Arizona this way... )
Maybe something is wrong with my engine that has reduced its power output...
I have been intending to regear the axles to 5.14's to help - but now that I think about it some more, since 5.14 is ~10% higher than 4.6 that'll only bump the RPMs up to maybe 2-300 (if my math is right)... I don't think that's enough to make a difference.
Anyone else have this problem with their auto tranny? It drives me mad. Maybe I'll buy some 25" tires for the street
Is there a simple way (I guess I could arrange a dyno) to tell if your motor is putting out the correct amount of power?
I put on a Calmini exhaust and a K&N drop in.... no significant difference. I corrected the timing... turns out it was advanced 5 degrees too far - but that didn't help (retarding the timing should have, in fact, reduced power... but I thought since the computer and fuel map are set up for 15 that it might help).
What's the best way to go here? I guess I need to establish whether there is an engine problem or not... and then decide what the best way to get more power is.
Then again, SLR has performance cams for $475... maybe I should go that route (how bad an install is that? I could probably do it - but I don't want to get myself in TOO deep.)
