0 registered (), 170 Guests and 0 Spiders online.
#42047 - 12/06/04 11:24 PM gears or air lockers on the back?
I've used the search feature.
With an automatic transmission, considering you have all ready done tires, sliders, lift and steering, which comes next gears or locking the back?
Please explain your answer.
thank you
#42048 - 13/06/04 05:55 AM Re: gears or air lockers on the back?
Toy Man Offline
Loc: Beaverton Oregon
Automatics - lockers. Manuals - gears.
Automatics can crawl slow enough to make use of the lockers. Manuals need the low gears first or they will be doing a lot of clutch slipping.
I have an auto with lockers.
My .02
Toy Man
#42049 - 13/06/04 06:20 AM Re: gears or air lockers on the back?
Agreed, although I would recommend both for our altitude and types of trails.
#42050 - 13/06/04 06:46 AM Re: gears or air lockers on the back?
DocNo Offline
Loc: NoVA
So if you had to pick one, would it be gears or lockers? 5 Speed question smile
Murderous Fire!
#42051 - 13/06/04 07:07 AM Re: gears or air lockers on the back?
Saline Offline
Loc: Fruita , CO
I am in a toss up between the gears or locker,which one first? I've noticed a HUGE loss of power in 4wd at around the 12,000 ft mark. Seems gears would help out tremendously in this area.Not to mention everywhere else. The advantage with lockers is obvious but you have to be able to have the umfff to move.
Desert Solitaire
#42052 - 13/06/04 07:15 AM Re: gears or air lockers on the back?
5-speed. Gears. Hands down, they completely transform the vehicle.
#42053 - 13/06/04 07:23 AM Re: gears or air lockers on the back?
You shouldn't be seeing any drastic change in power at any distinct altitude. I've driven my Xterra dozens of times over 13,000 feet, and in 1st-4Lo, it still feels almost the same as at altitudes closer to 9,000 feet.
Still, it has never not had enough power to drive up anything. Yes there is a decrease in power as the air thins out, but never enough to be described as huge.
#42054 - 13/06/04 11:55 AM Re: gears or air lockers on the back?
DocNo Offline
Loc: NoVA
That's what I figured you would say smile Thanks!
Hmmm, time to re-arrange the shopping list....
Murderous Fire!
#42055 - 13/06/04 12:24 PM Re: gears or air lockers on the back?
Saline Offline
Loc: Fruita , CO
Last year near the top of Imogene I was in 4lo 1st gear and barely made it up the last two hills near the Red Mountain overlook. I thought this was odd. Maybe somthing isn't right. The X was loaded with camping gear also. hmmm....
Desert Solitaire
#42056 - 13/06/04 02:28 PM Re: gears or air lockers on the back?
Scott Offline
Loc: Fort Collins, Colorado
I've had the same problem, though with my truck it seems to have some sort of high-altitude/been wheeling all day vapor lock type issues. If I stop and open the gas cap, it wooshes for about 10 minutes, and then the power seems better again. Imogene from the Telluride side is defintely one of the places I notice it. I also starting getting a gas smell from the pressure release do hicky by the right rear tire. Never been able to diagnose it. I don't know if having a gas tank skid makes the gas tank enough hotter to be an issue.
#42057 - 13/06/04 04:36 PM Re: gears or air lockers on the back?
Toy Man Offline
The type of trails you run will make a big difference.
Do a lot of rock crawling? Then low gears will be a BIG help but if you are running in mud or loose soils, then having the LOW bottom gear will limit your wheelspin and may not be the best choice.
At least that is my theory.....
Toy Man
#42058 - 13/06/04 06:23 PM Re: gears or air lockers on the back?
Kerensky97 Offline
Loc: Utah
Personally I think you should be able to tell what you need yourself.
If you don't have enough experience to know what your Xterra needs next you don't have enough experience to be getting into advanced offroading mods. Especially lockers, if your not an advanced wheeler lockers are just going to make it easier for you to break something.
-Dustin
Xterra101.com
#42059 - 13/06/04 06:28 PM Re: gears or air lockers on the back?
With the CALMINI gears you get a wider selection of useful gears to choose from. Picking the right gear, and achieving wheelspin is actually easier.
If you look at the crawl ratios below you'll notice that 3rd, 4th and 5th gear in (stock) 4LO are within the ratios of 4HI, making those gears almost redundant.
With the CALMINI gears only 5th gear falls within the ratios available in 4HI.
Code:
4HI
1 - 16.60
2 - 9.63
3 - 6.30
4 - 4.64
5 - 3.76
4LO (stock gearing)
1 - 33.53
2 - 19.45
3 - 12.74
4 - 9.36
5 - 7.59
4LO (CALMINI gearing)
1 - 65.06
2 - 37.75
3 - 24.72
4 - 18.17
5 - 14.74
Example, if you were in a situation where 2nd gear 4LO (stock, 19.45:1) was required to maintain wheelspin and momentum you would use 4th gear 4LO instead (18.17:1). If you slowed a bit and needed to downshift to 1st gear 4LO (stock, 33.53:1) you might be geared too tall, where the CALMINI gears would let you shift down to 3rd at 24.72:1.
#42060 - 13/06/04 07:52 PM Re: gears or air lockers on the back?
Ian;
Where in Denver did you have your's installed?
#42061 - 13/06/04 09:09 PM Re: gears or air lockers on the back?
Tynan's. Cyclemut, Vince and I did it (Cyclemut did the R&R and most of the work).
#42062 - 15/06/04 06:54 AM Re: gears or air lockers on the back?
Kaiser Offline
Regarding locker VS gears - as someone said, it depends greatly on where you are wheeling.
Those of us in Dallas mostly go to Barnwell - an old iron ore stripmine area(I believe) with lots of loose sand/sandstone... traction sucks and picking the line that provides the most of it is the name of the game. Gears wouldn't help much - a locker would be TREMENDOUSLY helpful.
My understanding of the wheeling in Colorado/Utah where GOX and GONE are is that there are high altitude problems and steep grade problems, but TONS of traction on the slickrock - so lockers would be less helpful and gears would be more helpful.
... so... your call based on location and type of wheelin'. If you're just rednecking in a field (mudding), for instance, you don't need either!
#42063 - 17/06/04 05:56 PM Re: gears or air lockers on the back?
OnlyOneDR Offline
Glen, one of these days I will make it up there to Barnwell to test your theory. Well, only halfway since I have a front LSD...
http://www.noas4x4club.com/
