129
#42047 - 12/06/04 11:24 PM
gears or air lockers on the back?
I've used the search feature.
With an automatic transmission, considering you have all ready done tires, sliders, lift and steering, which comes next gears or locking the back?
Please explain your answer. thank you
#42048 - 13/06/04 05:55 AM
Re: gears or air lockers on the back?
Loc: Beaverton Oregon
Automatics - lockers. Manuals - gears.
Automatics can crawl slow enough to make use of the lockers. Manuals need the low gears first or they will be doing a lot of clutch slipping.
I have an auto with lockers.
My .02
Toy Man
#42051 - 13/06/04 07:07 AM
Loc: Fruita , CO
I am in a toss up between the gears or locker,which one first? I've noticed a HUGE loss of power in 4wd at around the 12,000 ft mark. Seems gears would help out tremendously in this area.Not to mention everywhere else. The advantage with lockers is obvious but you have to be able to have the umfff to move.
Desert Solitaire
#42054 - 13/06/04 11:55 AM
Loc: NoVA
Originally posted by xoc: 5-speed. Gears. Hands down, they completely transform the vehicle. That's what I figured you would say  Thanks! Hmmm, time to re-arrange the shopping list....
#42055 - 13/06/04 12:24 PM
Loc: Fruita , CO
Last year near the top of Imogene I was in 4lo 1st gear and barely made it up the last two hills near the Red Mountain overlook. I thought this was odd. Maybe somthing isn't right. The X was loaded with camping gear also. hmmm....
Desert Solitaire
#42056 - 13/06/04 02:28 PM
Loc: Fort Collins, Colorado
I've had the same problem, though with my truck it seems to have some sort of high-altitude/been wheeling all day vapor lock type issues. If I stop and open the gas cap, it wooshes for about 10 minutes, and then the power seems better again. Imogene from the Telluride side is defintely one of the places I notice it. I also starting getting a gas smell from the pressure release do hicky by the right rear tire. Never been able to diagnose it. I don't know if having a gas tank skid makes the gas tank enough hotter to be an issue.
#42057 - 13/06/04 04:36 PM
The type of trails you run will make a big difference.
Do a lot of rock crawling? Then low gears will be a BIG help but if you are running in mud or loose soils, then having the LOW bottom gear will limit your wheelspin and may not be the best choice.
At least that is my theory.....
Toy Man
#42058 - 13/06/04 06:23 PM
Loc: Utah
Personally I think you should be able to tell what you need yourself.
If you don't have enough experience to know what your Xterra needs next you don't have enough experience to be getting into advanced offroading mods. Especially lockers, if your not an advanced wheeler lockers are just going to make it easier for you to break something.
#42059 - 13/06/04 06:28 PM
Originally posted by Toy Man: Do a lot of rock crawling? Then low gears will be a BIG help but if you are running in mud or loose soils, then having the LOW bottom gear will limit your wheelspin and may not be the best choice. With the CALMINI gears you get a wider selection of useful gears to choose from. Picking the right gear, and achieving wheelspin is actually easier. If you look at the crawl ratios below you'll notice that 3rd, 4th and 5th gear in (stock) 4LO are within the ratios of 4HI, making those gears almost redundant. With the CALMINI gears only 5th gear falls within the ratios available in 4HI.
4HI
1 - 16.60
2 - 9.63
3 - 6.30
4 - 4.64
5 - 3.76
4LO (stock gearing)
1 - 33.53
2 - 19.45
3 - 12.74
4 - 9.36
5 - 7.59
4LO (CALMINI gearing)
1 - 65.06
2 - 37.75
3 - 24.72
4 - 18.17
5 - 14.74 Example, if you were in a situation where 2nd gear 4LO (stock, 19.45:1) was required to maintain wheelspin and momentum you would use 4th gear 4LO instead (18.17:1). If you slowed a bit and needed to downshift to 1st gear 4LO (stock, 33.53:1) you might be geared too tall, where the CALMINI gears would let you shift down to 3rd at 24.72:1.
#42060 - 13/06/04 07:52 PM
Ian;
Where in Denver did you have your's installed?
#42063 - 17/06/04 05:56 PM
Glen, one of these days I will make it up there to Barnwell to test your theory. Well, only halfway since I have a front LSD...
