135
#42142 - 10/07/04 03:31 PM
clutch interlock cancel control
hi. i was looking at some old car magazines and i read that the early-mid 90's nissan 4x4 trucks with manual transmisions have a clutch interlock cancel control which allows the driver to not have to press the clutch when starting the car. this is helpful on uphill starts. i was wondering if anybody knows if the 2004 Xterra 4x4 with manual transmission has this clutch interlock cancel control? what about other nissan trucks and SUV's??
thanks.
#42144 - 10/07/04 04:28 PM
Re: clutch interlock cancel control
You can shell out the bucks for the Coolerman kit, or if you like, just put a simple momentary switch in parallel to the switch that's under the clutch pedal. Cheaper, simpler, but does require that you be more aware when using it.
#42146 - 10/07/04 07:15 PM
Loc: Oak Ridge, NJ
I have to agree Ian, all of Coolerman's Coolkits are done right. Here is a link to his site: http://www.globalsoftware-inc.com/coolerman/CoolKit1CIBS.htm
#42147 - 10/07/04 08:06 PM
No doubt, I agree, his stuff is great (I've got his reverse light kit myself) but I consider the CIBS to be massive overkill.
#42149 - 10/07/04 09:09 PM
And a simple switch in parallel with the one under the clutch pedal will do the same thing, which is all they had in the older Hardbody/Pathfinder days.
#42150 - 11/07/04 12:54 PM
Originally posted by xoc: How is that massive overkill ? Relays? LEDs? I believe Brent is trying to say that anything more than a parallel off the switch is a little much for such a simply operation. The CIBS is cool and all but my solution involved one switch, two wires, and doing solder taps to the clutch switch wires (I HATE wire taps). Cost me $5 and looks almost factory.
#42152 - 11/07/04 09:03 PM
Har har...
#42153 - 14/07/04 01:36 PM
Loc: Tacoma
Originally posted by xoc: Shell out the bucks ? Cheap bastard. Coolerman's kit is of exceptional quality and well worth the money. Exactly!
-Rick
#42154 - 14/07/04 02:19 PM
Originally posted by xoc: You can also just take your left shoe off, and wiggle your big toe up in there and hold down the switch. i have to try this one... is there anyway to just disable it permanently? tape it down or something?
#42155 - 14/07/04 06:09 PM
Of course, but it will bite you in the ass one of these days. I'd just bridge the switch with some wire rather than physically tape the switch down or something if you were game...
#42156 - 14/07/04 06:20 PM
Loc: Novato
IMHO, taping and clamping the switch is a good semi permanent way of bypassing it. Be aware of the ramifications of doing so! I am, for the most part, the only driver, and therefor comfortable with this set up. It works great when you need to start on hills...or any other time for that matter when you're in low range.
Rock on! Move the seat up Alice, so you can push the accelerator all the way down!
#42158 - 15/07/04 10:07 AM
Loc: san jose, CA, USA
Originally posted by k_enn: This modification does offer one advantage in terms of security. When I need to park in area of potential car theft, I simply reach down and unscrew the wire nut. Since the clutch interlock switch was not remounted in its backet (constant hitting of the wire nut by the clutch pedal might damage the wire nut), with the wire nut removed the starter will not turn regardless of whether the clutch is depressed.
k_enn Hey, that's nifty! By the way, what color wire nut did you use?
#42160 - 15/07/04 04:53 PM
Loc: Maricopa, AZ
For those with cruise control, won't disableing the CIS, not allow your cruise control to work? Seems to me if you touch the clutch while using cruise control, it turns it off. How would this affect the cruise control operation?
Ryan
"Duct tape is like the Force: It has a dark side and a light side - and it holds the universe together."
#42161 - 15/07/04 05:06 PM
That's a good point; if it does disable the CC, then I suppose you'd have to unscrew the wire nut before the roadtrip....
#42162 - 15/07/04 05:34 PM
Loc: Novato
The two are not related
#42163 - 15/07/04 07:10 PM
Originally posted by olebiker: The two are not related No kidding? I'm curious, then: what happens when you depress the clutch when the vehicle is operating on cruise control? (Not that I particularly want to try this ![[Uh Oh !]](graemlins/uhoh.gif) )
#42164 - 15/07/04 08:21 PM
I did just try it. Nothing happens. Cruising along at 50 mph(w/ cruise on), I depressed the clutch and began to slow.( cruise was, as is standard, in standby mode now) I pressed the resume button and began to come back up to speed. This was after starting the truck using the CIBS too. No problemo. ![[Smoking]](graemlins/smokin.gif)
#42165 - 15/07/04 10:01 PM
There is a second switch at the top of the pedal's travel. This one works the cruise control. The clutch-start interlock switch we are talking about is at the bottom of the pedal's travel.
#42166 - 16/07/04 08:05 AM
Right, separate switch for the cruise.
