Problem posting?
11/06/24 10:33 AM
11/06/24 10:32 AM
0 registered (), 221 Guests and 0 Spiders online.
#42233 - 29/07/03 10:48 PM Valve Clatter? 2002 SE
I did a search but didn't find anything...
I'm new to the group and to the charms of [Wave] the Xterra and was wondering if it's normal on cold/cool startup to hear a slight "clatter" for about 2-3 seconds?? Thanks in advance for any feedback..
#42234 - 29/07/03 10:51 PM Re: Valve Clatter? 2002 SE
ChuckH Offline
Yes; the Xterra has hydraulic lifters and it takes a second or two for oil to get pumped up to them on cold starts.
#42235 - 30/07/03 04:09 PM Re: Valve Clatter? 2002 SE
cbx Offline
Loc: Sacramento, CA
If you search the problems and annoyances section...you will find more than you need on that subject.
-cbx
"something clever goes here"
#42236 - 30/07/03 08:13 PM Re: Valve Clatter? 2002 SE
Thanks for the responses..should have dug a little deeper.
#42237 - 31/07/03 07:29 AM Re: Valve Clatter? 2002 SE
My other car is a 97 Miata and their engine is famous for this kind of valve train noise on startup and sometimes after a really hard, high rpm flogging.
There have been a million different answers for this passed around, but in my experience there are a few tricks that should apply to the Nissan as well.
1. Use an OEM oil filter with an anti-drain back valve and when changing it, pre fill the filter with oil.
2. Use a high quality oil, I normal use M1 synth in mine.
3. Do an engine flush every 3 or 4 oil changes. I have been using Gunk brand, but I have heard good things about Marvel Mystery Oil as well. You will be amazed at how nasty your oil will look after doing this.
If I follow the above, I never get valve clatter except when starting the car after it has sat for a week or so and it is only for 1-2 seconds. Looking at my oil pressure gauge, the second it comes up to good pressure, the lifters become quiet.
Hope this helps,
Web
