Problem posting?
11/06/24 10:33 AM
11/06/24 10:32 AM
0 registered (), 245 Guests and 0 Spiders online.
#423804 - 19/02/04 12:33 PM my x is drop on the pasanger side!!!!!!!!!!
my x have 17000 miles and yesterday i saw that the pasanger side has drop´in the frot 1.5inch and in the back 1inch what i need to do?????
#423805 - 19/02/04 12:40 PM Re: my x is drop on the pasanger side!!!!!!!!!!
I'm not completely sure I understand what your asking, but if I've deciphered it correctly one side of your X is lower than the other?
If that's the case, crank the T-Bar on the lower side until they are even, drive a couple of miles, re-adjust and repeat until you are even, then get an alignment.
Instructions to crank T-Bars are here: http://www.maxc.org/mods/torsionbarHOWTO.htm
#423806 - 19/02/04 01:29 PM Re: my x is drop on the pasanger side!!!!!!!!!!
Do you have alot of weight on one side?
#423807 - 19/02/04 02:42 PM Re: my x is drop on the pasanger side!!!!!!!!!!
i'm going to adjust the t bars
and the x is whitout load
#423808 - 19/02/04 02:57 PM Re: my x is drop on the pasanger side!!!!!!!!!!
Get an alignment done after adjusting the t-bars.
-dp [Smoking]
#423809 - 19/02/04 03:09 PM Re: my x is drop on the pasanger side!!!!!!!!!!
did you know the correct height for the x whit the stock tbars???
