0 registered (), 225 Guests and 0 Spiders online.
#424806 - 17/09/01 10:18 AM AAL & Torsion bars
SalsaX Offline
Loc: Aliso Viejo, Ca,
I only have room for about a 2" lift. (Low garage") I was looking at AAL & after market torsion bars. I was thinking about just adjusting the torsion bars, however, I've heard that it stiffens the ride. Does after market torsion bars do this also? Is this the BEST way to go? Will this lift too much? I only plan on installing a tire with more aggressive tread later on, not necessarily a taller tire.
Thanks,
Jim
#424807 - 17/09/01 11:27 AM Re: AAL & Torsion bars
BoarderPhreak Offline
Loc: Huntington, NY
If you're not going to put on taller/more agressive tires, I'd say leave it alone... The X will look a little silly if it's lifted with "dinky" tires on it... Not to mention affect your ride on-road for no reason. You'll also have to get an alignment done once you make these mods.
#424808 - 17/09/01 11:39 AM Re: AAL & Torsion bars
SalsaX Offline
Thanks for the reply. I guess I thinking that the clearence would help offroad.
#424809 - 17/09/01 01:29 PM Re: AAL & Torsion bars
Ag_xterra Offline
Loc: San Antonio, TX
if you only have 2 inches of clearance between the X and the top of the garage door opening i would say leave it like it is for now. once you get bigger and better tires judge that distance again then decide. remove rear sway bar and get quick discos for front for better articulation offroad if you havent already.
#424810 - 17/09/01 06:58 PM Re: AAL & Torsion bars
Loc: Huntington, NY
Right - the AAL will add a healthy 2" of lift and the torsion bars 1.5" so you'd be cutting it close with the garage. Especially if you change tires to a taller size.
#424811 - 18/09/01 07:57 PM Re: AAL & Torsion bars
SalsaX Offline
Thanks guys for all the advice. I'm putting a list together trying logicaly determine the best mods for me in what order. I do appreaciate the help.
