Yesterday at 10:44 AM
0 registered (), 239 Guests and 0 Spiders online.
#426389 - 23/06/05 11:58 AM Torx specs on the U bolts. (rear leaf)
Just gota around to laying my hands on a new set of U bolts for the rear leaf set, just curious what if any tork spec there was that I need to deal with.
#426390 - 23/06/05 12:33 PM Re: Torx specs on the U bolts. (rear leaf)
Kaiser Offline
My Frontier FSM says 72 to 80 ft-lb... Frontiers are spring-over instead of spring-under like the X - but I assume the same value will apply.
It also cautions to tighten in a diagonal pattern to keep the same amount of thread showing on all four bolt-ends (i.e. tighten it evenly so the spring pad sits level)
#426391 - 23/06/05 12:38 PM Re: Torx specs on the U bolts. (rear leaf)
Thanks Kaiser, I have been waiting for a reply I have to pick my kids up shortly and would like to get this done. smile
#426392 - 23/06/05 12:59 PM Re: Torx specs on the U bolts. (rear leaf)
The flippen U bolts I bought are too wide to fit through the bottom mount plate b y just a hair. Are there direct replacements or can I just round out the holes on the bottom mount plate?
By too wide I mean the diameter.
#426393 - 23/06/05 01:18 PM Re: Torx specs on the U bolts. (rear leaf)
BlueXU Offline
Loc: Sunnyvale, CA
Oh yes, since you say it almost fits, I would just ream out the holes with a round file (rat tail file) until the bolts fit. You'll have a custom fit at that point. Perfect. The holes are what we Engineers call "clearance holes" and are usually made oversize a bit so that the manufacturer can be a bit sloppy with the hole placement and size. It sounds like you have a "max material condition": largest bolt, smallest hole allowable.
-Bob
#426394 - 23/06/05 03:03 PM Re: Torx specs on the U bolts. (rear leaf)
I believe the Calmini U bolts say 50' lbs. At least that's what I torque mine to. Remember you're pulling on one bolt two ways. smile
