0 registered (), 138 Guests and 0 Spiders online.
#427466 - 08/06/05 09:11 PM Can someone help me out pls?
I recently bought Bilstein shocks from ebay,
Front : B46-1099-H0 (20% stiffer?)
Rear : BE3-6422-H0
My car is regular 4x2 2001 with no modification. Is it going to be problem installing 20% stiffer shock?
Thank you.
#427467 - 08/06/05 09:30 PM Re: Can someone help me out pls?
From what I have read, your ride will be very bouncy. Those stiffer shocks are made to accomodate the extra weight from modifications such as a winch/tire carrier bumper. So, I suppose if you dont mind a very rough/bouncy ride, they will be fine.
#427468 - 08/06/05 09:44 PM Re: Can someone help me out pls?
Is it going to be bouncy or stiff? Thanks.
By the way, i got all for 110 bucks plus shippng. I would have gotten those for 80 buchs...kind of make a mistake. They are all new.
#427469 - 08/06/05 09:56 PM Re: Can someone help me out pls?
gmaxis Offline
Loc: America's Finest city
Because they are stiffer by 20%, you will of course feel the difference in ride quality which in time you will get used to. But, not only did you get a good deal on the shocks, you should feel confident that your Bilsteins will last you longer.
SHIFT_paradigms
#427470 - 10/06/05 09:08 AM Re: Can someone help me out pls?
Thank you. I am going to put those at work shop. They charge me 100 bucks for that.
#427471 - 10/06/05 03:16 PM Re: Can someone help me out pls?
Why? rear shocks need a socket set, the fronts need a socket set, a pair of vice grips, and a cresant wrench( open ended wrenches work also)
Goofing off, it takes less then an hour..
#427472 - 15/06/05 12:58 PM Re: Can someone help me out pls?
Well it is done now ..paid 100 bucks to install. The ride is much better than before and really noticeable for couple of days. I like 20% stiffer shocks for fronts. It was all good until I drove my frined 97 old Honda Odyssey. Now I am not even sure i have bilstein shocks installed. That stupid mini van spoiled me. The van was solid stable. Xterra is much more bouncier than the van even after bilstein was hooked up. I coudl still feel the diffrence before and after the new shocks, it just not much anymore.
#427473 - 15/06/05 02:53 PM Re: Can someone help me out pls?
Well it is done now ..paid 100 bucks to install. The ride is much better than before and really noticeable for couple of days. I like 20% stiffer shocks for fronts. It was all good until I drove my frined 97 old Honda Odyssey. Now I am not even sure i have bilstein shocks installed. That stupid mini van spoiled me. I coudl still feel the diffrence, it just not much anymore.
[Freak] say what?
