Yesterday at 10:44 AM
0 registered (), 218 Guests and 0 Spiders online.
#428072 - 04/06/05 02:09 PM new way to disconect front swaybar
I've been running no swaybars for a couple years now. And now that my girl is driving it more on our camping trips,I had to come up with something. I'm usually entering the trail late at night to avoid all traffic. So unbolting the bushings and leaving the front swaybar bang around didn't appeal to me. I just preferred it off.
well I'll be testing my new (old modified)front swaybar. first thing I did was chop the thing in half laugh . the next thing I did was take a 10" peice of pipe, slide it over one side and welded it 5" onto one side of the swaybar. then I slide them together and drilled 2 hole on the other side equally space thorough the 5" pipe. Then one more hole for a zerk fitting in the center. I'm using two pins from an old set of rear quick disconnects.
If my welds hold and the pipe I used can handle the torsion loads, I can have the front disconnected in seconds!!
No pictures til I can find my card reader, (just moved).
#428073 - 04/06/05 04:21 PM Re: new way to disconect front swaybar
Mine comes off easy just un-bolt from the LCA and the cross member....then just turn the wheel all the way to the side and slide the sway bar out, no skid plate to un-bolt. and done....
but I like the idea....is it harder with an aftermarket skid...
#428074 - 04/06/05 05:25 PM Re: new way to disconect front swaybar
I don't have the skidplate on so it's not a problem. Bodylift and ARB. The truck drives a lot better and no funny noises laugh .
#428075 - 04/06/05 09:40 PM Re: new way to disconect front swaybar
Yea I hear that, I took mine off for a run last year and havent reconnected it... Made some evasive manuvers that skerd the crap outta me, but i guess im too lazy to put it back....
#428076 - 06/06/05 09:12 AM Re: new way to disconect front swaybar
what about just removing one side (bushings and such), and leaving the other alone.. shouldn't rattle..
#428077 - 06/06/05 11:25 AM Re: new way to disconect front swaybar
Kaiser Offline
Clever!!!
#428078 - 06/06/05 01:06 PM Re: new way to disconect front swaybar
I think it'll come in contact with the lower a arm and the tie-rod on top.
#428079 - 06/06/05 02:50 PM Re: new way to disconect front swaybar
XPLORx4 Offline
Loc: San Jose, CA
I came up with a similar idea for my truck's swaybar:
Pathfinder swaybar disconnect
My idea is more complicated than yours, but is similar in principle. The Pathfinder swaybar is loaded not only torsionally but also in shear, since the center portion is offset from the axis of rotation.
Since I never implemented my concept, I've simply been running sans front sway bar for 2 years.
I'm interested to see how your solution holds up long-term; whether it starts making noises over time, how much effect the 10" of pipe has on the swaybar, both engaged and disengaged.
4x4 in uppercase is $X$!!!
#428080 - 06/06/05 03:06 PM Re: new way to disconect front swaybar
Dean, so far on the road is great. I keep both ends in the pipe to prevent them from flayling around. I didn't think one pin could handle the stress either. After I drive it a little more I'll see how easy the pins come out.
when I can get the camera downloaded I'll have some picks of it and the custom stereo and cb install laugh . I've been busy. [Wave]
#428081 - 08/06/05 07:33 PM Re: new way to disconect front swaybar
[img] dscf0431 [/img]
#428082 - 08/06/05 08:38 PM Re: new way to disconect front swaybar
Just can't get the picture to come up. [Crybaby]
#428083 - 08/06/05 09:58 PM Re: new way to disconect front swaybar
#428084 - 08/06/05 10:21 PM Re: new way to disconect front swaybar
Sorry, but you have log to log in. It's the only way to I have been able to get iit to work confused
#428085 - 09/06/05 07:04 AM Re: new way to disconect front swaybar
BurgPath Offline
Loc: Knoxville, Tn
login:
xoc@xoc.com
Password:
password
I checked your album, nothing there. [Huh?]
Kevin
- 2008.5 Titan SE 4x4
#428086 - 09/06/05 09:39 AM Re: new way to disconect front swaybar
omg just email it to me andrew dot hadji AT gmail.com ill host and post it for ya
#428087 - 09/06/05 05:09 PM Re: new way to disconect front swaybar
can't even get them to e-mail right now. I'll have to use a different computer [Freak]
#428088 - 14/06/05 12:28 AM Re: new way to disconect front swaybar
slomatt Offline
Loc: Bay Area, CA
- Matt
#428089 - 14/06/05 05:08 AM Re: new way to disconect front swaybar
I think you need to undercoat that truck.
#428090 - 15/06/05 10:12 PM Re: new way to disconect front swaybar
