#428553 - 08/09/07 08:22 PM Another sway bar thread.
I've been searching, and I'm probably going to remove the rear sway bar when I get some new shocks, but people have been saying that without the sway bar, the shocks wear out more easily.
Is the wear a lot differerent from with a sway bar? Would stiffer shocks help at all?
#428554 - 08/09/07 08:32 PM Re: Another sway bar thread.
Save TJ some time.. smile Check the thread right before yours..thats SHOULD explain everything there is to know about sway bars...
#428555 - 09/09/07 02:38 PM Re: Another sway bar thread.
:rolleyes:
Naw...it doesn't wear the shocks out faster.
It prevents breaking the passenger side shock.
#428556 - 09/09/07 07:16 PM Re: Another sway bar thread.
oh cmon.. give me some slack, I'm new to this stuff. confused
I was just double checking. smile
#428557 - 09/09/07 07:37 PM Re: Another sway bar thread.
trust me, you're getting stack. welcome to XOC.
(insert XOC noob beatdown picture)
#428558 - 09/09/07 07:46 PM Re: Another sway bar thread.
Shocks can't wear out any faster w/o the swaybar. A shock is simply a damper for axle movement when you hit bumps on road. Ragardless whether the swaybar is on there or not the bumps are still being absorbed in the same fashion as the spring rate and damping rate are unchanged.
