Problem posting?
Today at 10:33 AM
Today at 10:32 AM
0 registered (), 306 Guests and 1 Spider online.
#429072 - 16/10/07 06:57 PM pml problems?
i went over some curbs today to get out of a parking lot and my front suspension was creaking and "popping" and making a lot of noise, like it was about to break? any ideas, is this cause the pml or is it something else.
#429073 - 16/10/07 07:38 PM Re: pml problems?
Rickster43 Offline
Loc: San Antonio,Texas
Probably...I have a PML on my X, and when I make a Rapid Turn into a Driveway or something, my front suspension makes a creaking and "popping" noise also...could be the Front Torsion Bars are Cranked Too much...just my 2 cents!!!
Your Personal CADD Monkey...
#429074 - 16/10/07 08:41 PM Re: pml problems?
Yes, you broke it. now you need an SAS, 35's and mt's.
#429075 - 17/10/07 08:08 AM Re: pml problems?
If the wheel was cranked to either side pretty hard then you might have been hearing the steering stops rubbing. No big deal.
#429076 - 17/10/07 10:13 PM Re: pml problems?
alright thanks, hmmm maybe it is broken, well i guess its time for a SAS
#429077 - 18/10/07 04:48 PM Re: pml problems?
And if you didnt have the wheel turned all the way, could be your U bolt on the axle loose. The supplied lock washers on mine totally fell apart (the nuts were torqued to the proper values) and therefore made the axle a bit loose on the leaf springs. Made an awful racket until I figured out what was wrong. For the longest time I thought it was coming from the front of the X.
#429078 - 18/10/07 05:43 PM Re: pml problems?
I have metal spacers in the front. If I go over a speed bump straight on, I get a loud metallic thumping sound, it's normal.
#429079 - 19/10/07 09:29 AM Re: pml problems?
You've got a totally different suspension setup.
