0 registered (), 136 Guests and 0 Spiders online.
#429870 - 17/06/05 10:47 AM rear swaybar discos -- anyone ever try this?
Okay, been reviewing a bunch of post going on about rear swaybar discos. And while the growing consensus is to simply remove it altogether, I think for my purposes, I'm going to keep it on.
Now, I had a thought after looking at TJ's pics. Has anyone ever made discos that remove from the axle? I'm thinking that by replacing the bolts that hold the bar to the axle (that also fix the bushings in place) with studs, drilling a hole through them sideways and clipping in a small stainless pin (similar to those used to hold the cross pin in a receiver hitch), you could simply pull the pins and rotate the whole bar (with the bushings attached)up out of the way against the spare tire or into the area where the spare used to be. To hold it in place, the bar could snap into small spring clips mounted somewhere.
I think I might try this over the weekend. I can't imagine the hardware for this costing hardly anything. Everything I'm visualizing is readily available at my local marine hardware store, so it will be stainless steel.
Any thoughts?
#429871 - 18/06/05 07:25 AM Re: rear swaybar discos -- anyone ever try this?
The two ends would still be on the links to the body...and you'd swing the bar back towards the spare well?
That seems like a reasonble solution...I suppose the only issues are the ability of the axle attachment scheme to resist the torque loads and not rattle as the axle rocks, etc., and when disco'd to miss the exhaust on the drivers side, hit thew shock/springs, and to not accidentally come unclipped and act as an anchor over obstacles.
It wouldn't work with the spare, as the bar would be in a position to hang up going over things...but w/o a tire in the way...it should be cool.
